Jb14
Hi Folks I am posting this in hopes that it can help you all not to have to go through what I had to for a year with and air conditioning issue with my 2005 Expedition.
Issue:
My A/C started to not be cold so I took it to a trusted mechanic who diagnosed my issue as needing a Freon charge. When the $125.00 service was done the trusted mechanic said that my A/C compressor was week and needed to be replaced (after charge blowing coldish) So I purchased a complete kit (not from ford but a good kit anyways) and had it replaced (parts and labor $1200)
Issue 2:
After job was complete the system ran cool but not cold like I expected then in a month and a half the system was blowing hot again. Many trip back to the not anymore trusted mechanic produced no resolution and the same blowing coldish to hot air (and ALLOT OF FRUSTRATION)
Now to the year later when he finally took my Expy to a friend mechanic of his who diagnosed my issue as a bad condenser and clutch fan.
Now down to the real bend me over solution. I had the not trusted mechanic repair the parts that was the issue and he only replaced the clutch fan and not the condenser>>> Guess what with only the clutch fan replaced my A/C works just as good as it did before all the issues.
Long story short replacing the $100 clutch fan solved my issue I ended up spending close to 2k for in parts, time, gas and agony when it was just the clutch fan.
Hope this helps someone out there!!
REVISION; Finally fix part 2
Cautionary tale of bad mechanics Ive never had this much trouble before. But my Fixed A/C stopped working again I took it to a new mechanic who after alot of trouble shooting found the problem.
Which was again the Clutch Fan that was replace 10 days ago by the bad mechanic. Turns out Expy's on certain parts do not like aftermarket part which is what the bad mechanic installed (Auto Zone part) so after another $700 and a factory ford clutch fan It seems to be working properly.
So if an issue pop for the Ford part.
Issue:
Issue 2:
