hot weather bogging?
bcmaxx
trail,b.c.
It was warm out today got to 102 . Well warm for here. Our 01 was bogging pretty good off the line. Fine one you got your foot into it. But a general lack of power . Intake air temp read 139. Normal??
toms89
technical advisor
MD
As IAT and/or engine temps rise it pulls ignition timing advance progressively. This can create a noticeable drop in power.
Not sure if you have "cold air intake" or not. If its pulling air from the engine compartment it will be much hotter while sitting at idle. As soon as you get moving it will drop due to air flow through the engine bay.
B
bcmaxx
trail,b.c.
Yes supposed cold air intake. That would make sense. Thanks
BakerEdition
EF Chaplain
Thats why I left the factory set up and enhanced the Gotts mod by actually forming the PVC that goes through the fender to go all the way inside and conform to the shape of the outer fender skin. this stops the air rushing by the tube and directs it into the intake...what you are experiencing is nothing abnormal on these trucks when it gets hot...mine does the same thing and I have a programmer running timing 2 degrees advanced.
B
bcmaxx
trail,b.c.
Oh wow, I may have to look into doing this. I run true ducted cold air on my jeep so I havent really experienced this. I have a programmer I can adjust timing on, would you play with timing on a stock setup?
Swetrid
Pa
Ford has tsb for this concern.
Printable View (94 KB)
TSB
02-12-3 DRIVEABILITY - ENGINE LACKS POWER WHEN OPERATING IN HIGH AMBIENT TEMPERATURES ABOVE 38C (100F) - VEHICLES EQUIPPED WITH 5.4L ENGINE ONLY
ENGINE - 5.4L - ENGINE LACKS POWER WHEN OPERATING IN HIGH AMBIENT TEMPERATURES ABOVE 38C (100F)
Publication Date: JUNE 13, 2002
FORD: 2000-2002 EXPEDITION, F-150
ISSUE:
Some vehicles equipped with the 5.4L-2V engine may exhibit a lack of power condition when operating in ambient temperatures above 38°C (100°F). This may be caused by the Powertrain Control Module (PCM) calibration which retards the ignition timing to prevent detonation when the Inlet Air Temperature (IAT) reaches 60°C (140°F) or above. This may be more pronounced during stop-and-go driving.
ACTION:
Verify the condition. Reprogram the PCM with the latest calibration and on 2000 and 2001 F-150's, install body plugs behind Coolant Overflow Bottle if missing. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
For 2000-2002 F-150's and Expeditions equipped with a 5.4L 2V engine, if a lack of power occurs only when the IAT is above 60°C (140°F), reprogram the PCM to the latest level calibration listed in this TSB.
For 2000 and 2001 F150's, install Body Plugs (383181-S and N807093-S) behind the Coolant Overflow Bottle. Refer to Figure 1 for location and plug button installation. These plugs will reduce the engine compartment heat moving into the air cleaner inlet area.
Body Plug Installation
Remove air cleaner inlet. Refer to Section 303-12.
Remove jack handle.
Remove upper radiator sight shield.
Disconnect radiator overflow hose from radiator to degas bottle.
Position degas bottle away from body plug hole area.
Install body plugs in location shown in illustration.
Position back degas bottle Torque to 9 N-m (80 Lb-in).
Connect radiator overflow hose.
Install upper radiator sight shield.
Install jack handle.
Install air cleaner inlet. Refer to Section 303-12.
PCM CALIBRATION INFORMATION
Application Old Part Number (-12A650-) Tear Tag New Part Number (-12A650-) Old Calibration New Calibration NGS/WDS Qualifier
2000 F-150, 5.4L, 4R70W, Fed/Alt/Can YU2F-AGA JSQ0 YU2Z-AGB 0F514A0A06 0F514A0A06 WDS B19A.5 Release or Later
2000 F-150 5.4L 4R70W Fed/Alt/Can (Non LEV) YU2F-AHA RZM0 YU2Z-AHB 0F514N0A06 0F514N0A06 WDS B19A.5 Release or Later
2000 F-150, 5.4L Calif, 4R100 YL3F-LE CPE4 YU7Z-BHA 0F514D0B11 0F514D0B11 WDS B19A.5 Release or Later
2000 F-150, 5.4L Calif, 4R100 YL3F-ATE SNL4 YU7Z-BZA 0F514E0B13 0F514E0B13 WDS B19A.5 Release or Later
2000/2001 F-150, 5.4 49S/Alt/Can/Mex, 4R70W YL3F-AUD UAT3 YU7Z-CAA 0F514F0A12 0F514F0A12 WDS B19A.5 Release or Later
2000 F-150, 5.4, 4R100 Fed/Alt/Can, Heavy Duty YL3F-BCB GMH1 YU7Z-DNA 0F514G0A11 0F514G0A11 WDS B19A.5 Release or Later
2000 F-150, 5.4 Fed/Alt/Can, 4R100 YL3F-BDB JBR1 YU7Z-DPA 0F514H0A11 0F514H0A11 WDS B19A.5 Release or Later
2000 F-150, 5.4L, 4R100, Calif. YC3F-PE NCG4 YU7Z-DRA 0F514M0B11 0F514M0B11 WDS B19A.5 Release or Later
2001 F-150 5.4L, Calif, Base/Harley, 4R70W 1U7A-BKA KKM0 1U7Z-BKB 1F514E0B11 1F514E0B11 WDS B19A.5 Release or Later
2001 F-150, 5.4L 4R70W Fed/Base/Harley 1U7A-BLA LDN0 1U7Z-BLB 1F514F0A11 1F514F0A11 WDS B19A.5 Release or Later
2001 F-150, 5.4L, Base, Calif, 4R100 1L3F-TD PTJ3 1U7Z-BYA 1F514D0B10 1F514D0B10 WDS B19A.5 Release or Later
2001 F-150, 5.4L, Fed, 4R100 1L3F-ATD ILM3 1U7Z-CDA 1F514G0A10 1F514G0A10 WDS B19A.5 Release or Later
2001 F-150, 5.4L, Fed, 4R100 1L3F-AUD CRG3 1U7Z-CEA 1F514H0A10 1F514H0A10 WDS B19A.5 Release or Later
2001 F-150, 5.4L, Calif, 4R100 1L3F-UD LBJ3 1U7Z-CFA 1F514M0B10 1F514M0B10 WDS B19A.5 Release or Later
2002 F-150, 5.4 Base, Calif, 4R100 Bi-Fuel 2L3A-TC TGR2 2U7Z-ANA 2F514D0B06 2F514D0B06 WDS B19A.5 Release or Later
2002 F-150, 5.4 Base, Calif, 4R70W 2L3A-VD VMF3 2U7Z-APA 2F514E0B07 2F514E0B07 WDS B19A.5 Release or Later
2002 F-150, 5.4 Base, Fed, 4R70W 2L3A-WD WUQ3 2U7Z-ARA 2F514F0A07 2F514F0A07 WDS B19A.5 Release or Later
2002 F-150, 5.4 Fed, 4R100 2L3A-YC RPW2 2U7Z-ASA 2F514H0A06 2F514H0A06 WDS B19A.5 Release or Later
2002 F-150, 5.4, Calif, 4R70W 2C3A-CB BGR1 2C3Z-CCC 2F514A0B05 2F514A0B06 WDS B19A.5 Release or Later
2002 F-150, 5.4, Calif. 2L3A-ATB BWJ1 2L3Z-ATC 2F514E0B16 2F514E0B17 WDS B19A.5 Release or Later
2002 F-150, 5.4, 49S 2L3A-AUB UEV1 2L3Z-AUC 2F514F0A16 2F514F0A17 WDS B19A.5 Release or Later
2000 Expedition, 5.4L 2V 50S/Alt/Can 4R100 YL1F-BE ZUT4 YU7Z-AYA 0B314B0511 0B314B0511 WDS B19A.5 Release or Later
2001 Expedition, 5.4L, Fed/Calif/LEV, 4R100 1L1F-CC PWS2 1U7Z-BXA 1B314B0510 1B314B0510 WDS B19A.5 Release or Later
2002 Expedition, 5.4L 4R100, Less Mexico 2L1A-FB AKD1 2U7Z-ALA 2B314B0505 2B314B0505 WDS B19A.5 Release or Later
2002 Expedition, 5.4L 2V A/T Mexico 2L1A-JA JJP0 2U7Z-AMA 2B314B0M00 2B314B0M00 WDS B19A.5 Release or Later
PART NUMBER PART NAME
383181-S Body Plug
N807093-S Body Plug
Obtain an Authorized Modifications Decal (FPS 8262 - obtainable through DOES II, 25/pkg) and list the date, dealer number, and summary of modifications performed. Select a prominent place adjacent to the Vehicle Emission Control Information Decal suitable for installing the Authorized Modifications Decal. Clean the area, install the decal, and cover it with a clear plastic decal shield.
AUTHORIZED MODIFICATIONS
THE FOLLOWING MODIFICATIONS HAVE BEEN MADE:
Reprogrammed Powertrain Control Module (PCM) Per TSB 02-12-3
THESE MODIFICATIONS HAVE BEEN APPROVED, AS APPROPRIATE, BY EPA AND CARB.
DEALER NUMBER:------------------------------------------DATE:
CHANGE AUTHORITY:
FPS 8262 9/78 FORD MOTOR COMPANY PRINTED IN U.S.A.
OTHER APPLICABLE ARTICLES:
NONE
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
021203A Reprogram Powertrain Control Module: 2000, 2001, 2002 F-150, F-150 Super Crew, Expedition 0.6 Hr.
021203B Reprogram Powertrain Control Module And Install Body Plugs If Missing: 2000, 2001 F-150, F-150 Super Crew 0.9 Hr.
B
bcmaxx
trail,b.c.
TSB
ISSUE:
ACTION:
SERVICE PROCEDURE
Remove jack handle.
383181-S Body Plug
N807093-S Body Plug
CHANGE AUTHORITY:
NONE
WARRANTY STATUS:
Thankyou very much, I just got it reflashed at ford for a sixpack :) , I also found another cause of the problem, ( well this is what was doing it) the iat was turn sideways, so flow through the sensor was blocked, I turned it with the flow and it immediatly remedied the problem) I talked with edge and k&n tech support. I had no idea it would make any difference
