VIN decoding & options/packages
RI-Matt
Rhode Island
Hi Matt,
First I would like to say Thank You. I think it's awesome that you take the time to do this for people. We are looking at Expeditions to purchase. IT is critical that it has the Premium (HD) Towing package. We are looking at one that we like, and the sales person said it was standard. I'm confused, as it has the 5-V (Class 4 hitch), but the 4 prong plug. Could you possibly run this VIN, please ? Also, can you provide where you are getting this info, just in case this only has standard package, the search will continue. We need to be able to tow 7700 lbs and hopefully just install the Electic Trailer brakes, by mounting and buying the plug in jumper.
1FMPU165X6LA06564
Sorry this Expy does NOT have the HD Tow Pkg.
All the 2nd and 3rd Gen Expys have the same Class IV hitch and at least the 4 prong plug standard. When opting for the HD Tow the actual hitch doesnt change.
Info is obtained from Fords site available to dealers and repair facilities. A password is needed for access.
Matt
the_smiths_30
Pennsylvania
Thanks Matt, it is VERY APPRECIATED.
Bummer, we really liked that one. If I'm reading all of these posts correctly, in order to get an EXP from standard to HD, it would require:
Larger Trans Cooler
Larger Radiator
9 prong plug
additional - Electronic Brakes
Thanks agin for your help, not to mention how quickly you did it. I was wondering if there's anything to look for to differentiate between the 2. This was a Special Service Unit. I've seen a few "XLT Premiums".... Just trying to avoid any unnecessary leg work :) Would the 9 (or 7) Prong plug be a sue sign it had the HD PAckage ?
In your OPINION, would you recommend towing a 7,700 lb GVWR Travel Trailer withthe standard tow package.
RI-Matt
Rhode Island
Larger Trans Cooler
Larger Radiator
9 prong plug
Your looking for a 7 prong plug in addition to the 4. Most SSV Expy's were for law enforcement and municipalities so they weren't optioned out with HD tow packages.
I think without the HD tow pkg you're tow rating is under 6000lbs so I would say NO.
If you find another one you're interested in just shoot me a PM and I will see what I can find out.
Matt
gigantapithic
Calgary
Awesome,
Just found this thread - too bad it's not sticky'd in the towing section :)
I was trying to find out this info earlier and no dealer would give me an accurate answer or call back after I had asked the question. I have a class IV and a 7-PIN and a wire harness for a trailer brake. But am not savvy or knowledgeable enough to find the tranny cooler.
Would you be able to run my VIN? Would really appreciate it!
1FMPU18525LA77785
Unfortunately the Expy is at the shop as I just had it blow up on me this weekend and I think it's sounding like the broken fuel injectors that the warranty was extended to cover. Been driving it for two months and wondering if it's toast now :(
Thanks!
tojohnso
There is more to towing than the weight rating. You might want to read up on how length plays in to it as well to be safe. Especially when you are talking RVs.
RI-Matt
Rhode Island
Awesome,
1FMPU18525LA77785
Thanks!
A Canadian one.
Build Date: 31.01.2005
Vehicle Line: Expedition (2003-)
Body Style: 4 Door Wagon
Version: Ford Series
Engine: 5.4L 3V V8
Transmission: 4 Spd A/T AODEW/4R75E W/TSS
Drive: 4WD
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning: HD ATC Air Conditioning
Paint: Charcoal Beige
Medium Parchment
Less Underbody Protection
With Manual Liftgate
119" Wheelbase
Eddie Bauer
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Michigan Plant Built
Canadian Sales
With Convenience Group
Less Exterior Dress Up Package
Less Sales Badge
Less Military Vehicles
Less Special Value Packages
Less Exterior Appearance Pack
Less Functional Upgrade Pack
With Memory Pack
Feature Content Group 2
2005 Job No.2 Program Control
Less Electronic Stability Control
Less Safety Pack
Less Special Language Label
English NAS Owner Handbook
With Fixed Rear Vent Quarter Window
With Privacy Glass
Standard Ovrhed Console & With Rail
With Full Floor Console
Memory Adjustable Foot Pedals
With Carpet Floor Covering Level 1
Front Floor Carpet Mats
Rear Floor Carpet Mats
Drv Sunvsr-Dual Lt/Illum/Mir/HMLK
Pass Sunvisor-Dual/Lt/Illum/Mirror
With Colour Keyed Running Boards
With Integrated Roof Rack
With Accent Wheel Lip Moulding
Less Lower Body Moulding
Less Side Auxiliary Step
With Electrochromic R/View Mirror
Driver Power Memory Heat Mirror
Pass Power Heated Memory Mirror
With Black Exterior Mirror
With Signal Mirror System
With Drivers Heated And Cooled Seat
With Pass Heated And Cooled Seat
With Leather 2nd Row Seat Material
With 2nd Row Dual Captain Chairs
With Third Row Power Folding Seat
With Driver 6 Way Pwr.Seat Adjuster
With Pass 6 Way Power Seat Adjuster
With Programmable Driver Seat
With 3rd Row Vinyl Seat Material
Trailer Tow Prep Pack
With Front Towing Hook
Less Engine Oil Cooler
Body Coloured Exterior Door Handle
With Door Entry Remote Control Unit
With Remote Keyless Entry
Less Sun Roof
Front Bumper Painted Accent Colour
Rear Bumper - Step Accent Colour
With Front Licence Plate Bracket
Less Air Curtain Restraint
With E-Coated Steel Spare Wheel
With 4 Wheel Tyre Pressure Sensors
Less Rear Shock Absorbers
7.5 X 17" Sport Aluminium Wheel
P265/70R 17 A/T OWL
With Standard Engine Cooling System
Immersion Heater Engine
With 49 State/Non Green State Req
With Standard Suspension
3.73
Less Rear Axle Limited Slip Diff
Less Exhaust Pipe Extension
Normal Fuel Fill
With Standard Transmissn Oil Cooler
4X4 2 Speed Transfer Case With Tod
With Non Locking Fuel Cap
For Unleaded Fuel
Steering Wheel-Leather Wrapped + CK
Redundant Controls - Steering Wheel
With KMH/MPH Speedometer
With Message Centre
Less Reverse Proximity Sensor
Standard Duty Battery
Standard Duty Alternator
Prem AM/FM Stro/CD Changer/Clock
With NAAO Radio Frequency
Less Headphones/Sockets - Rear
With Audiophile Sound System
Less Television Package
Less 4X4 Version Pack
With Homelink
With Complx Refect Headlamp Design
With Daytime Running Lamps
With Front Fog Lamps
With Interior Courtesy Lamp
With Automatic Headlamp On/Off
Charcoal Beige
Generic Country Group 2
Less B&A Control Codes Issue 030388
Less B & A Control Codes (9270)
With Overspeed Warning Disabled
(+)"CDN"
(-)"N"
(-) GVMT Service Administration
(-)"USA"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"CHN"
(-)"CHL"
Based on the red highlighted wording yours did NOT have the "factory" HD tow package. A previous owner may have added the 7 Pin and wiring harness.
Also this comes up:
Outstanding Field Service Actions
07M08 - EXTENDED WARRANTY COVERAGE ON FUEL INJECTORS
Matt
gigantapithic
Calgary
A Canadian one.
Also this comes up:
Matt
Lol, why the "A Canadian one"?
Guess this makes it obvious no HD tow package (on top of your red items)
Oh wow, especially the part on extended warranty coverage on fuel injectors. Is there a way I can find out which ones were already replaced? Other than tracking down old owners?
Thanks - really appreciate it!
RI-Matt
Rhode Island
The Canadian comment was because its the first one I've been asked to run.
Matt
RI-Matt
Rhode Island
Yes, you are right, sorry.
1FMPU18L4YLB57866
Thanks
Dave
The older ones have less info available.
Build Date: 23.03.2000
Engine: 5.4L Modular SOHC V8
Transmission: E4OD(4R100)
Drive: 4WD
Axle Ratio: 3.55
Paint: Dark Toreador
Medium Parchment
With Running Boards
With Lighted Running Boards
With Drivers Heated Seat
With Heated Passenger Seat
With 3rd Row Bench Seat
With Heavy Duty Trailer Towing
Power Tilt/Slide Sun Roof
7.5 X 17" Styled Steel Wheel
P265/70R 17 A/T OWL
3.55
Rear Axle Limited Slip Differential
Elect Premium AM/FM Stereo/Cass/Clk
With CD Player Autochanger
Dark Toreador
Matt
rwedmundson
St Albert AB Canada
Matt can you decode my 2006 Expedition, I was really hoping it had the HD Tow but suspect that it does not. I am about to buy a Holiday Trailer and could use this info. If it dos not have the tow package, I am wondering how and how much it would cost to upgrade to it. 1FMFU20546LA37092
