Lift and tire purchase
Billy Fay
Miami
Looking to purchase a Truxxx 3 inch lift for my 2010 2wd xlt and 31.5 tires. Curious as to what overall height increase will be and if anyone has pic's with this tire size for comparison?
FordandPolaris
Saint Cloud, MN
Well it would be mostly the lift, since 31's are pretty close to stock. Go with 33's if you can, that will look better.
SOLISIMO
Ft. Lauderdale
3/2 lift u will be able to fit 33s and depending on the offset u might need to trim the front lower lip corners. No biggie
Lane24
technical advisor
Alberta , Canada
I agree with everyone !!!!! 33's at least. ( Then you'll want 35's !!!)
I know they are different Gen Expy's... but for your comparison... Here's mine when I had 31's and the lift. Looked awful.
Had to 35's on right away !!! You can see the pics were taken 3 days apart . lol. Could not stand the way it looked after the lift.SANY1266.jpg
tallsville
LA
i know different gen but if you look at my pics you can see mine with 33's before and after a 3.5/2.5 lift
gkelly
nj
Go as big as you can because after you lift a little your gonna want to go bigger
B
Billy Fay
Miami
So I a being told I can only go285/70/17 on the 2010 2wd. Anybody disagree?
Dib52
Wylie, Texas
Sounds about right, your limiting factor is 2wd...for 4wd vehicles, you can squeeze 35's in the wells. Even with having 4wd, I stayed in the 33" range(295/70/17).
As far as which kit, they're all pretty much the same...however when you say Truxxx 3in, it's really a 3/2(if you get the right one) identical to the ReadyLift 3/2. All 4 coils get spacers. And they'll only work with non-air ride suspensions.
SOLISIMO
Ft. Lauderdale
Who told you this? The third generation 4wd and 2wd are the exact same height
B
Billy Fay
Miami
Thx Solismo and Dib52. So Soilsmo, your suggestion for largest tire size on my 2010 Exped, with the Truxxx 3/2 lift?
SOLISIMO
Ft. Lauderdale
33s, I had an aggressive offset on my old truck and had to cut the front bumper. Truxx is basing there information off of an F150 stand point. Trust me I wanted bigger and higher but its just not possible without major mods. I have seen 35s stuffed in a 2nd gen but he had to cut alot too.
B
Billy Fay
Miami
Ok so I thought I was set on the Truxxx 3/2 lift till I saw the Cali Lean 3.5/2.5 lift. Anyone know if it will wk on my 2010 2wd?
Dib52
Wylie, Texas
I'm sure it would, just don't know if that extra .5 is gonna make that much of a difference. You originally only wanted 33's unless that plan changed. Cali lean=not my cup of tea...towing a 6000lb boat gets my nose in the air just enough, don't need to set it up that way as a daily driver.
I still stand behind my original advice...Truxxx3/2 and 295/70/17 on my factory rims so back spacing isn't an issue. Just my .02
B
Billy Fay
Miami
Thanks Dib52. You are partially correct on my goal. The overall goal is to get noticable height and size difference not, over the top.
