Exp05_intake
Has eny body here tried nitrous on a expedition
Unless you build the motor, I would not consider this at all. Stick with forced induction.
...And even if you did build the motor, I would still stay away from it.
It makes pulling a boat out of water really easy.![]()
Hey mc0311 grunt did you retard your timing if so how did you do so. I recently purchased a zex nitrous system and it does state that if going 100 or above you should retard your timing by 2 or 4 degrees
