00 Expo Spark Plug Issue
chrisluke50
Idaho
Hi,
I was doing a tune up on my expedition today and I got to the right rear plug and removed it okay, but now I can't the new plug to go back in. There was nothing special about the old plug, it was the same as the rest. I didn't twist the plug out at a weird angle or anything. I tried for over an hour to get the new plug to go back in and it won't catch the threads. It just turns and turns. Any ideas?? I'm at a complete loss on why the new plug won't go back into the cylinder.
toms89
technical advisor
MD
Did you check and make sure an insert did not come out with the old plug?
If someone had installed an insert it is not that uncommon for them to come out with the spark plug.
C
chrisluke50
Idaho
There was nothing on the old plug. I was thinking maybe the threads were messed up and was looking into possibly using a thread chaser.
B
bedrck46
Had the same happen on a 4.6 engine what I did was to remove the plug from the socket wrench then took some paper and shoved it into the socket wrench then placed the spark plug in the socket this caused the plug to extend out a little bit and I had no problem in getting the plug to screw into the hole Give it a try
C
chrisluke50
Idaho
So the plug socket might be interferring with the installation of the plug? I will try that a report back. Thanks for your input guys.
FordandPolaris
Saint Cloud, MN
All he was saying is it might be just far enough into the socket that it does not reach down to the threads. The paper gives it enough distance to reach the threads.
C
chrisluke50
Idaho
Still nothing. I'm pretty sure I messed the threads up. The plug goes in and it feels like the thread try and catch but spins in an oval.
Am3gross
Va
What do the threads on the old plug look like... Maybe try another plug in the same hole.... What about putting the old plug back in?
C
chrisluke50
Idaho
Old plug looked fine. Threads looked ok. No noticable difference, same plugs. For some damn reason I can't get the new or old plug to go back in. I'm going to order a snake camerea to take a look inside the cylinder to see whats up. Almost certain there isn't an insert. The socket reached the plug to take it out just fine. Is there a special socket that is supposed to be used? Took a little bit of force to get it out, but it came out. I can get the plug and socket into the cylinder and a u joint on and try and turn it by hand. It turns and doesn't seem to be catching the threads. It acts like it catches but then can't turn it by hand. I put on an extention and the ratchet when turning it never engages. Tried vaccuming the cylinder out thinking some debree possibly fell in the cylinder and is in the way but sounded like nothing was sucked up. I'm praying to baby jesus (kidding) that I won't have to pull the head off, which sounds like it's out of my league. I was going to leave that plug alone, but figured if I was going to change the plugs, might as well change that one too.
superexpy
Covington wa
I was going to buy this and keep it in my glove box encase the unthinkable happens sense its only 30$
C
chrisluke50
Idaho
Right on, thanks for the info. I've ordered a usb snake camera which should be here in the next few days. Once I've taken a look within the cylinder I'll report back and let everyone know for sure whats going on. :005:
xJohnnyOx
Idaho
Any update? Also, are you in the Treasure Valley area?
xJohnnyOx
Idaho
ChrisLuke50, Are you still with us?
I have been following this post to see if ChrisLuke was able to get his Expedition going again. Sure would like to know how it was resolved.
Chris, if you are out there, let us know.
JohnnyO
B
bedrck46
he should have had the snake camera by now would be nice if people up date their post just to help others find answers
