Subwoofer enclosure for 3rd gen
Tcris3
Chandler, Arizona
I was looking to put 1 or 2 10 inch subwoofers in my 2008 and heard there was an enclosure that fits under the second row seats but have not been able to find it...anyone know of one? Also I plan to keep 3rd row seats folded down most of the time and want a fairly stock look... Any ideas for a fairly inexpensive enclosure that would work well for this? Even a larger enclosure that can be moved and fit behind the 3rd row would be fine.
Thanks for your help!
sgtowing
Supporting Members
Valrico, Fl
JL Audio stealth box. Thst is whst I'm going to get
Sent from my SCH-I535 using Tapatalk
oblivion
Ontario Canada
To my knowledge no one makes an under the seat enclosure unless your thinking of an all in one sub like this Clarion SRV250 Theres just not enough space and the fact the seats fold down. With an enclosure theres no way they would if they are anything like my '99 second row.
The Stealth box is a good option for the stock location and a single 10
Newport News, VA
U will have to get the jl stealthbox...anything under the seat will have to be custom...not enough room with the levers for the seats to fold up and down and it will need to be shallow mount subs...L3 from kicker and rockford makes one
T
Tcris3
Chandler, Arizona
Thanks for the input! I was looking at the stealth box but it is made for up to 2002 the 3gen EL only will they fit the regular 3rd gen?
sgtowing
Supporting Members
Valrico, Fl
For the first gen, use the 1st gen one. For the second and third gens, use the third gen El one.
WarrenG
Everett WA
I replaced the stock Sub with a Kenwood KFC-XW800F. Its a slim line Sub that sounds great and fits in the Stock space.
T
Tcris3
Chandler, Arizona
Warren, did you just add the sub or did you do an amp too? If so what amp did you go with and did it fit in the factory location?
Thanks
Newport News, VA
U won't fit an amp in the factory location with the sub in there...the factory amp is like 5x5 attached to the sub enclosure...a couple of us have put aftermarket amps in there...I have a huge power acoustik 6000d mono amp in there...
Newport News, VA
A few only changed the sub but I believe there are extra wires to the sub
bricekin
South Bend, IN
Depending on what amplifier you go with, you can actually get it to fit back there with the Stealthbox. I'm using a HD900/5 that's crammed inside my dash under the radio.
Class D amps that have enough power to run that sub are getting smaller and smaller.
