ggoblue
so I notice in the fall that the 2001 expedition [I stole from the new wife] doesn't make much heat. of course I notice it a lot more once its zero and below this week. I don't like riding around without my sidekick [the dog]. its too cold to leave him in the car when I'm running around right now.
the front and rear heat are both affected.
I've had the coolant flushed twice in the last 2 years...maybe they flushed crap into the core? didn't have a problem before that.
I put a flush tee in the heater hose so I could make sure its full up. I think this was the hose into the heater core because its warmer than the other one. as I pour coolant into the tee I can see the level rise in the bottle.
I changed out the thermostat. that didn't help.
I get a little surge of heat when I'm making some rpm's. then it goes back cold.
so I'm down [in my mind] to either a clogged up core, or the water pump is too weak to feed the heater core.
if you swapped the two heater hoses would that flush it? wouldn't it work the same anyway?
there's a tee in the heater hoses and I think that's to feed the rear core.
thanks in advance.
thanks in advance.
