Performance Mass Air Flow Sensors?
TactialMonkey
Washington
Does a "Performance" MAF really make a difference or is it a waste of money I was looking at the Jet performance and the Summit Racing ones and I'm just curious as to is it really makes a difference. Thanks guys!
nonwoven29
Carsom city Nevada
It's not a performance item Persia. However you do need to upgrade as your air & fueling needs increase.
IE: you install larger fuel injectors,hot air intake,custom tune etc. most MAF sensors have a heated Element "resistor" that measures the difference in air temp.
Just to buy it with out needing it would be a waste IMO.
boobie33
Norcal
So would it be worth it if I only have a cai installed? I am planning on getting one soon.
Sent from my SGH-T999L using Tapatalk
TactialMonkey
TactialMonkey
Washington
I have a K&N 77 series intake and summit racing ignition coils and a crank breather with some e3.53 spark plugs and I'm going to get a new MAF and an throttle body spacer and probably a new thermostat so my truck will run cooler
toms89
technical advisor
MD
I agree with nonwoven.
A mass air meter is a waste unless you need it for tuning purposes. IE you max out your stock meter and need more range.
What they are trying to sell you is a "larger" mass air meter with the theory bigger is better that most tend to buy into. Much experience over the years via racing, testing and tuning I disagree with this.... its how everything works together as a system.
When you flow significantly more volume of air than stock (combo heads, intake, cams or power adder) is when you need to consider an aftermarket meter along with injectors and a tune.
nonwoven29
Carsom city Nevada
If you do buy a new maf you will 100% need a retune. The ECM will freak. Run rich,lean and or set a SES/CEL DTC! There is no way around this dude.
Replacing coils is a good proactive PM plan.
The crank breather umm?? I'm not so sure you want to do this man. If you do not intend to use the pcv system at all , then your a okay. On the other hand if you do use it , your short changing yourself.
IMHO TB spacers were and have always been a Farce!!! Kind of like the E superchargers, turbonators.
There is a useful application in TBI & Carberted engines. They help increase volume and have some minimal heat reduction effect.
The thermostats function is to open at a preset temp. This is done with diffrent coil/spring lengths/diameters. It will open sooner or later depending on the tstat you use. It opens up the cooling/circulation in the engine to the radiator.
It's not going to do much in the way of helping with heat rejection unless you have a larger radiator.
IMO if you don't want to use power adders the best bang for your buck are,
75mm or larger throttle body.
Port match the throttle body Plenum/elbow to the throttle body. Then polish it to a high luster.
A true cold air intake. Some where other then in the engine bay. Bumper fender area etc.
Ditch your cats altogether, use a true free flow muffler. Any type with a true straight threw design and no chambers or crappy baffles.
Long tube full length headers. Short tube if you don't want to hassle or afford the cost of them.
Last but not least a custom tune. Not one of those cookie cutter tunes out of the box.
With all the above I wouldn't be surprised if you gained up to 40bhp/ lbs tq give or take.
toms89
technical advisor
MD
They do sell "stock replacement" after market meters that are OE exempt. Your statement is of course true if you get a recalibrated aftermarket meter.
Didn't even catch this reading it the first time. Yep.... with a breather your introducing a vacuum leak. Removing the pcv valve will eliminate pulling fresh air through the motor and the block/oil can get contaminated quickly.
Agree 100%
Think that is a bit optimistic but much better mods.
nonwoven29
Carsom city Nevada
True Tom. I was being a little optimistic. I was thinking in the tune advance the crap out of the timing using 91. Octane.
Thinking he was close to sea level being in WA.
Never thought about a stock MAF replacment.
boobie33
Norcal
Thanks guys. Much learned
TactialMonkey
TactialMonkey
Washington
The crank breather just goes on where the oil fill cap does it stopped my truck from low speed sputtering so I'm going to leave that on and so basically I shouldn't mess with this motor anymore and just save to build the DOHC I want in the truck?
FordandPolaris
Saint Cloud, MN
That would be sick! That is a mod (albeit a huge one) that would make total sense.
TactialMonkey
TactialMonkey
Washington
I want to save up to get a newly rebuilt one then have it sent to be ported larger and then cams and a supercharger on top just because its possible and I want to caus why not
boobie33
Norcal
Got a link to this crank breather you are talking about?
TactialMonkey
TactialMonkey
Washington
its just a little k&n filter from orileys that i stuck in the oil fill hole and it seemed to of stopped my truck from randomly sputtering so im happywith it haha
toms89
technical advisor
MD
It's odd that it stopped it from sputtering because you are introducing a vacuum leak. Generally the pcv draws air through the block via the hose on the drivers side valve cover that gets its air from the intake after the meter..... so its 'metered' air its pulling through the pcv valve.
Maybe blowby is overwhelming your pcv system creating positive pressure on the intake side as well causing issues?! Then breather will help vent any excess pressure so it does not end up in the intake.
TactialMonkey
TactialMonkey
Washington
I'm not entirely sure but yeah I realized its a vacuum leak but I think sence my EGR valve is probably clogged or broken that leads me to believe something else may be blocked in one of the PVC tubes so until I can get a new EGR system I am going to leave the breather on
toms89
technical advisor
MD
Who knows.... i'm just speculating..
If its working for you at this point, wth... I would leave it on too. :)
The DOHC navigator heads/ motor is a nice upgrade. More than a few "lightning" guys that have done this mod. They typically go the turbo route then as well because they would need adapters or modified intake for a supercharger.
Built turbo DOHC navigator motor FTW!
TactialMonkey
TactialMonkey
Washington
No turbos Whipple twin screw supercharger is what I'm looking at... My friends 04 STI is turbo but I like superchargers on big gassers if it was a diesel then turbo all the way but I'm in the cams and supercharger route
