Spark Plugs Causing Engine Jerk?
FireTractor
I just purchased an '07 with 91k miles, and I have noticed the engine "jerking" when accelerating. After doing a lot of research, the problems sounds like it could be related to the spark plugs needing to be changed? I knew when I bought the car that this job would need to be done soon. So, my question is: has anybody else experienced this "jerking" problem that was fixed by changing the spark plugs?
On another note, the first time I noticed this problem, the emissions system light came one, but the following times I have had this engine jerk, the light did not come on.
Thank you for any insight you can provide.
Kyle
B
bedrck46
Did you get the codes read after the emissions system light came on? If not then take it and have the codes read and then post them on the forum.
Suggest you replace plugs and COP's and see if that solves the jerking problem. Also you may want to change all fluids including a trans flush.
metaldrgn
somewhere
Is it fine at idle and you only really notice at higher speeds? Spark plugs are the main cause of that.
F
FireTractor
No, I did not get the code read, but the light has not come on since then. When I have them change the plugs I'll get the coed read.
splintrcel
Milwaukee
I have noticed that as teh coil packs age the engine jerking starts. Does the jerking change with humidity? I have fresh plugs and mine does that on certin days.
metaldrgn
somewhere
Yes I've read of a few people that have had that problem in high humidity or rainy days. If I remember right, changing the cop fixes it but I think the problem lies in the connectors.
tonydiv
technical advisor
Middle River, MD
In general, people tend to blame spark plugs for issues too often. Most problems usually come from cops or sensors. Plugs don't usually fail suddenly and start causing problems.
metaldrgn
somewhere
They do usually just start going bad one day or at least it seems that way. I've had multiple cars and that's what happened on more than one not to mention all the forums with this issue. I don't know why ford cops have such a high fail rate, but spark plugs should not be overlooked.
My07EL
Vegas
Update as promised. Just changed the plugs at 90500. Stutter at cruising speeds went away. Used a makita cordless impact driver and 0 broke. I did have to break 7 of them free 1/4 turn with a ratchet but used the impact before and after.
valenrandy
Houston, Tx
If you dont mind me asking, which plugs did you replace them with? I'm currently looking to replace mine with MC SP515 or the MC SP509. Just trying to figure out the best/proper/correct ones to use.
Thanks
F
FireTractor
Thank you for all the replies. I had the plugs changed yesterday, and none broke! They also found a bad coil, so the problem seems to have been resolved.
wadesdad
Congratulations! Happy motoring Kyle. I don't think the COPS or plugs are a "problem" if you consider how often we used to have to change wires and plugs. You got your plugs at the right time. COPS turn south at 120k plus miles and are EASY to install.
Barjrob1972
2007 Expy EL EB. Mine had the same problem. At lower rpm's it felt like the truck was missing when I gave it gas and then on a long trip, I went to pass and it starting missing at higher rpm speeds.
A plug change fixed my issues, too.
Factory plugs at 108k miles.
Nightsun
Had this same issue with jerking/hesitation. Dealer told me all COPS were bad except for #5. They changed these out on warranty. They suggested replacing the plugs too but at $400 bucks I am going to do it myself this weekend using an impact and some pb blaster. Anyhow, the jerking issues went away completely by just replacing the cops. My 07 5.4 has 128k miles on it now. Need to research to see what plugs are best to replace the stockers with.
toms89
technical advisor
MD
I realize this thread has just be revived but....
I believe the opposite to be true. With the internet and forums like these people tend to blame the cops first when plugs are a wear item, the gap grows over time and they can and will misfire or foul. In fact as the gap grows it puts more load on the cop and increases its chances for failure. The spark is always looking for the path of least resistance. Whether its across the plug gap, through insulator to ground or coil to ground. The higher the load on the motor the higher the resistance to fire across the gap as well. That's why boosted vehicles use much smaller plug gaps.
I personally have never had a cop fail yet. Spark plugs yes...
What's interesting to me is I rarely see cop failures mentioned on lightning forums. Sparks plugs all the time. But then they push the motors much harder but at the same time run significantly smaller gaps decreasing the likely hood of misfire and the demand on the cops.
