Will this "275/65R18" fit?
2005exp
eastbay
It's for the F150 truck wheels and tires.
Will these fit without any issues?
Would mileage be different?
Thanks
05 expy currently with p265/70r17 stock tires
mrford60
SE pennsylvania
those two tire sizes are almost the same overall hight the speedometer difference is about 1 mph faster for the 18", they should work fine.
AskMeLater
Amarillo, Texas
I have 18" F-150 wheels with that tire size on my 03 Expy.
You will not have any problems. Direct bolt-on.
2005exp
eastbay
Thanks for the picture.... Looks nice!
Didn't work for me tho, seller had a 5 lug rims but tires were great. It had 90% threads on them. Have to keep looking out!
Generally, any F150 stock rims will work, right? Even 20 inchers?
Cheers,
Spades
Riverside
I have the 18" F150 wheels as AskMeLater with 275/65-18 on my 03 Expedition also, but mine rubs on extreme sharp turning. Doesnt bother me, but good to know before you go out and buy
svtl919
MN
would 18 inch rims from a 2011 ford f150 fit on my 2005 ford expedition. bolt pattern is the same and offset looks the same no hub issues are there?
TommyJoe
Syracuse, Indiana
What say you!
I just bought (couple months ago) a 05 Expi, confused here for sure.
The tires and wheels are not the stock wheels and tires,
they are P255/55R18. With what looks like F150 Wheels (Polished)
Spare is P265/70R17 and stands about 4 inches taller than the ones
that are on the Expi.
WHY would someone change this so drastically? I realize the 70R17's
weigh in at about 71lbs each with factory tire and wheel (Black Steel
12 hole with 6 lug)
For me it sits too low and would like to go back to the factory tires and
wheels, I just ride that way, I like things factory as they must have had
a reason.
Comments?
TommyJoe
Syracuse, Indiana
They may have, but you would think the door sticker would have been changed to reflect the change,
and now I have to pull the speedo and see if that was changed to reflect 4 inch smaller tires.
tallsville
LA
my ex did that to my expy. Brought it home with some smaller f150 rims and tires, that she bought from her dad. Cant remember the exact size but they were 29" tires vs 31" stock. Kept them on until i got my current set up, which was a few years. Luckily i got rid of both.:flamingdevil:
Spades
Riverside
No need to pull the speedo. Just compare it against a GPS. I should point out however that every car ive compared to a GPS usually reads 1-2 mph faster than the GPS readings, so id say allow for a little bit of tolerance before assuming its been altered.
255s were another stock tire options, so maybe they got a deal on the set?
The F150s had the 255 but they i believe they were 255/65-18
