Changing the upper intake manifold and metal line
l1j2h
port Hardy
I have 1999 expedition 5.4, 4x4.
I have a problem of leaking coolant.
It comes from the upper intake manifold gaskets.
I ordered the upper intake manifold gaskets and the lower intake manifold gaskets.
I want to know each torque sequences.
The upper intake manifold has 10 bolts and the lower manifold has 8 bolts.
Please give me some information. foot-ib
And I think that I should change the metal coolant line the goes from the water pump to the back of the motor.
I think that I need to buy. But because of leaking coolant, ....
Please give me some opinion.
Thank you
From Paul.
L
l1j2h
port Hardy
The answer
The torque sequences of the upper intake is 20 foot pound.
The torque sequences of the lower manifold is 8 foot pound.
I got it
Ripp
Dirty Jersey
It was just a heads up. Seen ppl make that mistake before.i just look at the attachment and seen inch pounds n didn't do no math to see if u did.
Bedrck47
Elizebethtown, PA
The following was copied from the 1999 Service Manual
Installation
Install the upper intake manifold gasket.
Position the upper intake manifold and loosely install the new bolts.
Tighten the bolts to 10 Nm (89 lb-in) and then an additional 90 degrees in the sequence shown.
Install the lower intake manifold:
Position the gaskets.
Install the intake manifold.
Install the bolts.
L
l1j2h
port Hardy
Question
Thank you all friends,
I have a question. I have 1999 expedition 5.4, 4x4.
I can see leaking coolant from the back side of engine.
The car repairman said that I need to change the upper intake gasket.
I am curious. Is it possible?
So, I will change this if I receive a part.
Please give me some info.
Thanks.
