What recommened grade of gas to fill up your expedition?
FordGirl1983
Richmond, VA
What recommended grade of gas to fill up your expedition?
I haven't been in this forum in a while but just want to ask what's the recommended gas grade to fill up your expedition with? I know regular gas makes that "pinging" noise and I heard regular is not really good for your expo. Thanks for your kind reply.
FordGirl1983
FordGirl1983
Richmond, VA
Thank you. Well I stopped using regular and started using midgrade, made a big difference of the performance, no funny noises. I don't know if I wanna go back to regular. Glad the gas prices are dropping. :)
stamp11127
Temple, Georgia
Unless you have a 5.4 DOHC your engine is designed for 87 octane. If it is pinging on that octane you have a problem that is causing pre - ignition.
FordGirl1983
FordGirl1983
Richmond, VA
I'll try my best to describe the noise I heard. My expo is currently at 302k miles and still counting.
FordGirl1983
FordGirl1983
Richmond, VA
When accelerating on the road, the noise get a bit louder. Oh I don't think it was a "pinging" noise, it's more like a bubbling, flapping noise. I try my best to describe the noise better lol.
98EXPnSRQ
Sarasota, FL
I had a slight ping when accelerating on 87 octane. It went away when I changed the spark plugs.
FordGirl1983
FordGirl1983
Richmond, VA
A little update this morning on my commute, I filled it with mid grade and the rattling sound went away. I assumed that sound is from "bad gas". That's all I know so far.
montecarlo31
What are you seeing for timing advance and what are you seeing for retard? If it's going away with a 2 point increase sounds like timing or a plug issue. I'd test coils and replace plugs / wires. While you are in there might as well do air and fuel filters to knock out the big stuff.
toms89
technical advisor
MD
I fill up with the highest octane possible but mine is running boost. :) The higher the octane the more aggressive I can get with the tune.
tojohnso
in my '99 the only issue I had was when I put in 93 thinking I would get better mileage on the highway. If the engine isn't tuned for it, bad idea. I normally filled with 87/89 whichever was available and cheaper. I do the same now with my '11.
thewishkah
New York City
I used to use 87 now I mostly use 89, with 87 the truck felt sluggish and would rough idle once in a while. Even after replacing the air filter, gas filter, spark plugs, pcv valve and cleaning the egr ports that were mostly clogged. All of those things didn't help my gas mileage at all. Never had a CEL but I think my coil packs are next on the list. I decided to try 89 after gas prices started to fall and it runs better, and has more pep when on the pedal.
No members online now.
Landsbutter
