Towing with 2007 Ford Expedition
baf0929
NY
Hi,
I am new to this forum so please excuse me if I'm repeating things that have already been discussed. I have a 2007 Ford Expedition and I currenlty tow a travel trailer that is 29'long and has a dry weight of 4,585lbs. I tow with no problems. I am looking to upgrade my camper to one that is 33' long and has a dry weight of 6,630lbs. Looking at the Ford tow guides it says I can tow up to 9,200lbs if my Expedition is equipped with the heavy duty tow package. The problem is that I don't know if I have the heavy duty tow package. I have a print out of the features by running the VIN and found that I do have the following features: heavy duty alternator, 3.73 drive ratio, heavy duty battery, 5.4 engine, standard duty suspension, less front and rear shock absorbers, suspension--coil spring, trailer tow prep pack, auxillary transmission oil cooler. Does "trailer tow prep pack" mean I have the heavy duty tow package??? I've called two local Ford dealers and got two different answers. How can I tell if I have the tow package or not? I want to be 100% sure of what I can tow before I buy a new travel trailer. If I don't have the heavy duty tow package can I still upgrade to it, and what is needed to upgrade? How much can I really tow with the tow package and without it? Any help would be greatly appreciated. Sorry for all the questions...I'm really confused!
JUST4FUN
Admin
Moderator Administrator
Il
read some of the post here , it not that the expedition cant handel the weight the wheel base is what your going to have the problem with for 33' its just too short
IMHO
B
baf0929
NY
Am I out of luck due to the length or is there something out there (anti-sway) that would make it work? I currently have a reese 800lb weight distribution tow package with the dual cam sway control. What is the max length that I can tow with my Expo? Thanks for your help...This forum is very informative!
tonydiv
technical advisor
Middle River, MD
The weight distributing hitch should counter the length issue, it's going to put weight back on the front wheels. Most of the "tow" add-ons revolve around cooling various fluids. Since you have the trans cooler you should be ok. You could always add an oil cooler for engine oil and perhaps beef up the rear springs with one of the many products out there. (air helper springs, air shocks, etc) I'd pick something that you can adjust, so it doesn't screw up the ride when you're not towing.
The other thing that my friends who tow all the time all swear by is synthetic fluids. They all run synthetic fluids in the diffs, t-case, trans and motor.
Something that really helps out my truck is the power programmer. The tow mode makes the shifts much more snappy, which cuts down on slippage and thus heat.
B
baf0929
NY
Just to clarify I have a Reese weight distribution hitch (14,000lbs) and the tongue weight is 1,400lbs or 1,000lbs depending on pin hole position. The sway bars are Reese V-5 rated, 10,000lb gross trailer weight, 800max hitch weight. This is what I currently tow with. Thanks for the infor...I'll have to look into the bigger tranny and oil coolers.
Orange County, CA
If you look through the front grill and see a small transmission radiator attached to the larger radiator you most likely have the Heav Duty Tow Package. I check my 07 for that when I bought mine. You will be fine with what your towing. Good luck and drive safe.
B
baf0929
NY
Towing / Rear suspension
Does anyone recommend bulking up the rear suspension for towing with my 07 Expo? If so, what do you recommned?
tonydiv
technical advisor
Middle River, MD
Probably the easiest thing to use are the air bags that go inside of the rear coils. They have an onboard compressor that allows you to change the ride on the fly. The best part is that they don't change the ride when you're not towing. A buddy of mine added them to the leaf springs on his F150 and he loves them.
B
baf0929
NY
Towing
I finally found some facts on towing with my 2007 Ford Expedition. With the 3.73 axle ratio, I can tow up to 6,000lbs or 9,000lbs with the heavy duty tow package. The heavy duty tow package has an ugraded radiator, and an 11 fin (versus 7 fin) auxillary tranny cooler. I only have the 7 fin auxillary tranny cooler. I will be upgrading to a bigger tranny cooler as well as an oil cooler. Does anyone know if this will suffice or do I need to upgrade my radiator as well? I'm looking to tow a camper that has a dry weigtht of 6,800lbs. Thanks for all your help!
jimmyv13
Do you have both the 4 pin flat and the 7 pin round connector by the hitch for trailer wiring?
KWT2000
NINE MILE FALLS
that is a nice hitch just remember to stay with in the limits of your expy, i would ask and check your self in the trailer you are looking at is designed to be pulled with a light duty vehicle, things to look for are axel placement and holding tank placement... as for the radiator upgrade if your gonna be in the mountains i would do it if not your stock radiator will do fine... IMO the trailer your looking at is too long for the expy... good luck with your decision and drive safe
B
baf0929
NY
I'm not towing long distances (1 to 3 hours away). I'm going to change the fluids over to full synthetic and I'll put beefier (thicker sidewall) tires on the rear end. We'll see how she does with that for now.
B
baf0929
NY
Right now I only have the 7 pin round connector. I don't remember if I originally had the 4 pin flat that was converted to the 7 pin by the RV shop. It didn't have the 7 pin when I bought it.
RUFFSTUFF
GEORGIA
All the Expy's (at least 2005-up) come with a transmission cooler. The towing package makes it a bigger one. If yours didn't have a 7-pin connector stock you most likely do not have a towing package.
FWIW, my tranny cooler is 8-fins not 7.
How did you get this info? I'm looking for it as well...
