Electrical Problems
bigwick70
Gilbert, WV.
Was wondering if anyone has seen this happen? My 1997 Eddie Bayer wont start. I had to boost it the other day and it started right up, and ran, till i went about a mile down the road and shut it off then it wouldnt start back. Not even crank. At first I thought the solenoid went out so i bridged it over from the fire wall and it started but i noticed none of the gauges are working or lights, and the battery is dead. I notice before i tryed to bridge it over to start it, all the lights and guages were on. Also when i take the hot post off the battery the engine quits. Also, im confused as to why it wont crank from the key switch and cranks fine from bridging the solenoid. Please help!!!:Violin:
stamp11127
Temple, Georgia
Classic sign of no output from the alternator to the battery. Usually cause is a failed alt but can also be a harness issue.
Do you have a voltmeter, battery charger and ability to read wiring diagrams?
The no start from the ignition switch is electrical, may only be a failed starter solenoid.
Don't start tossing parts yet - we need to find what failed.
If the battery is dead, how did it crank? Are you always having to jump it?
bigwick70
bigwick70
Gilbert, WV.
I do have a small voltmeter and am somewhat familar with diagrams. I usually dont have to jump start it but it sit all winter and i had to this time. It had been started after that time sitting but i had it parked due to a dead inspection sticker. It started up the same day the problem occoured, and i took it for a drive then when i shut it off it wouldnt re start. When i bridged the solenoid over it barely cranked like the battery was almost dead. I hooked the cables back up to get it to run again and when it started, thats when i noticed the dash lights, etc were not on. I'm thinking the solenoid might be stuck maybe and draining power? Does this sound right to you? Pretty sure the altenator is shot because i took off the hot terminal and the motor quit. When it is running i have no guages or lights whatsoever, but if the engine is not running the guages, interior lights, ETC, all work. What voltage should my meter read if the battery is good? It also reads amps and olms.
stamp11127
Temple, Georgia
Fully charged is 12.6 v, 12.4 is 75%, 12.2 is 50%, 12.0 is 25%.
Charging voltage should be 13.8-14.1v - engine running of course.
If the solenoid was stuck closed the starter would be energized all the time - would be toast by now.
bigwick70
bigwick70
Gilbert, WV.
I hear you there on the stuck solenoid. I checked the battery and it is reading 9.6 V, on the setting 200. not running...
bigwick70
bigwick70
Gilbert, WV.
Need to charge it back up then test alt output.
Ok, i just went and checked the lead going to the fuse link that goes to the solenoid and was getting 0... Then i went to the other side that runs to the solenoid and it read 12.6, also the hot terminal reads 12.6 while it is running. Do you know what im calling the "Fuse link" on the fire wall that connects to the solenoid and the altenator? there are 2 of them. the other one runs from the solenoid through the inside of the truck?
I put another Fully charged battery in it and when i remove the hot (Red) terminal the motor quits.
The truck was running then i tryed to turn on the headlights and the guages went crazy and it quit running. The anti theft was flickering too. The key switch wont work with the good battery either.
I really appreciate your help man. thanks
stamp11127
Temple, Georgia
You need to check the voltage at the battery with the engine running. Take one reading with it at idle and another with it about half throttle.
If both show 12.6 or less take another reading with the red meter lead on the output stud on the back of the alternator and the black meter lead on the alt case. Engine should be running. Be careful of the fan with the meter leads.
Do not remove the battery while the engine is running, that is an old habit from pre electronic days. Today it is a bad idea and possibly an expensive mistake.
bigwick70
bigwick70
Gilbert, WV.
Ok i checked it from the hot post on the altenator and it read 0.07... Actually it was jumping around. It is reading everything from 3.5 to 7.5 jumping back and forth on the battery, at idle and half throttle. I noticed the anti theft is flickering too. It is the only light in the dash that works while it is running.
bigwick70
bigwick70
Gilbert, WV.
I just went through the fuses under the dash and one was blown. it was #21, a 15 amp on the diagram, (Starter Relay, Junction Box Fuse #20). Thats what it says in the Owners manual. Going to start it and see what that changes... That was the only one blown...
It blew the new fuse when i hit the key switch...
stamp11127
Temple, Georgia
There are two fuses to the alternator that should be checked also. See attached diagram.
  • 012-001.pdf
bigwick70
bigwick70
Gilbert, WV.
I think i know the two youre refering to. The two on the firewall i was talking about earlier, or actually there are three there, near the solenoid and battery, (Altenator Megafuse-175 amp), and (Alternator field minifuse-20 amp). Do i check them with the OLMS on my meter to see if their making a circut? Or?
Also what i was calling the solenoid is actually the Starter Relay... My fault. sorry...
Well its late in the hills my friend. Talk to you tomorrow...
stamp11127
Temple, Georgia
Disconnect the battery, set meter to ohms and place one lead on one side of the fuse and the other lead on the other side. An infinite or "ol" means the fuse is blown.
bigwick70
bigwick70
Gilbert, WV.
Ok i checked both 175 amp and the small 20 amp and they're all reading.
stamp11127
Temple, Georgia
Next step would be to take the alt out and have it tested. A good shop will be able to tell you output voltage and amp output. If you go to Autozone or the like they may not know what you are looking for and may have to read the values yourself. If they only have a green light for passing then cross your fingers.
bigwick70
bigwick70
Gilbert, WV.
If i am understanding the diagram and mechanics correct, (Just me thinking here and trying to understand), with the key switch not putting power to the starter and when i bridge over the starter relay and it does, it has to be a starter relay gone bad because it is the only mechanism that allows the power to be bridged between the key and the starter and having that function. Also the interior fuse 21 (Starter Relay, Junction Box Fuse #20) keeps blowing. That is telling me something is blowing that fuse because it is grounded inside the Starter Relay. Feel free to correct me. I have just enough inteligence on this to get me into trouble lol...
The Alternator or the battery one has to be bad also. Will get both tested tomorrow when the auto parts opens.
stamp11127
Temple, Georgia
The fuse can be blowing due to a failed ignition switch if your referring to diagram 013-006 fuse 21. Other areas of trouble have been the harness in the steering column. Try adjusting the tilt wheel to a different position and see if the fuse blows.
You may consider getting a circuit breaking instead of blowing a bunch of fuses.
When does the fuse blow?
When you replace it or when you turn the key?
bigwick70
bigwick70
Gilbert, WV.
It only blows when i hit the key. Am not sure if the alternator i putting out the wrong voltage, what should it be reading at the lugg on the alternator?
Going right now to get a new relay and get the alternator tested... ill holler back and let you know how that goes.
stamp11127
Temple, Georgia
You should test the starter relay before swapping in a new one.
Charging voltage should run from 13.5 to 14.1v depending on the vr.
bigwick70
bigwick70
Gilbert, WV.
well been kinda busy this week and not had much time for working on the truck but i did manage to swap out the relay for a new one. That was the problem with the ignition. All guages ETC are working norman now.
The alternator isnt charging though. I cant get a reading from it at all. Going to start on that now. :)
Oh and i charged the battery 3 days ago and its still charged so it is still good...
the starter relay fuse didnt blow this time and the truck starts from the ignition also...
