There are two fuses to the alternator that should be checked also. See attached diagram.
Disconnect the battery, set meter to ohms and place one lead on one side of the fuse and the other lead on the other side. An infinite or "ol" means the fuse is blown.
The fuse can be blowing due to a failed ignition switch if your referring to diagram 013-006 fuse 21. Other areas of trouble have been the harness in the steering column. Try adjusting the tilt wheel to a different position and see if the fuse blows.
You may consider getting a circuit breaking instead of blowing a bunch of fuses.
When does the fuse blow?
When you replace it or when you turn the key?
