03' overhead dvd monitor
DFendersExpy
Norwalk , CT
Well I've been looking to Add headrest monitors to my Factory overhead dvd. Does anyone happen to know if there's a plug in adapter for adding extra monitors to the factory dvd system? Or how to locate the Video output in the system so I could attach a RCA plug to it... Thanks in advance
Newport News, VA
u will need to buy a video out with multiple line outputs...should be able to get them for about $50 to do this job...some may cost $100 or so for the name and number of outputs it has...the more outputs...the more it will cost
Newport News, VA
its a splitter...just like a cable splitter...so u take the video feed and connect it...then connect all ur other video lines to ur other screens...where to put it...wherever you want to put it...
DFendersExpy
DFendersExpy
Norwalk , CT
No I guess my question I should be on the factory overhead unit. Where would I connect the extra monitors On there? There is no video out on that unit only video in.
Newport News, VA
you would have to find the feed by tearing down the headliner...the feed will have to be connected...then connect the splitter...the prob i see you having is that you will need to have very long video cord at least 12ft long cuz you will have to run them from the headrest to the floor up to the slpitter...for each
DFendersExpy
DFendersExpy
Norwalk , CT
That's the million dollar question. Which wire is the out put video feed.
Newport News, VA
i cant help u any further...prob best to take to a shop...try asking parts store to look it up on their computer
tsingson
NC
You will probably want to get a signal booster with the multi outs. The more you split the signal, the weaker it gets.
