output wires on the factory amp for sub...
johnboneske
I haven't taken mine apart yet, but can anyone tell me what wires the output of the factory amp are for the sub?
I am gonna ad a connector to it like this so I can unplug the factory sub and add a single 10" DVC sub in its own box and use it sometimes, and also be able to plug the factory sub back in when I want to remove it and use all three seats or haul something.
http://www.amazon.com/Molex-Female-Extension-Adapter-Sleeved/dp/B00DBTIVHG/ref=sr_1_4?ie=UTF8&qid=1452019356&sr=8-4&keywords=4+pin+molex+connector+48%22
Thank you!
Lostneye
NY
I don't have wiring diagrams but be careful choosing a sub. Some on the factory subs are DVC. The factory THX system in my Navi had a 2 Ohm DVC and if I remember correct 50w per coil rating on the sub. Stick with the same Ohm rating and I would look for a high efficiency rating to make the most of the relatively weak factory sub amp.
Newport News, VA
on the amp itself on top of the sub...all the wires are for the amp...if u go to my photo album on here I believe I have pics of where I used an audio converter where I added to 12s behind the 3rd row while keeping the factory sub still plugged in...if not...i'll dig up pics to put on here showing what I did...
johnboneske
johnboneske
yeah, I have a 92db/1w1m 10" dvc 4 ohm sub so I am thinking it should be efficient enough. I have it in a 1.05 Ft3 box which is tuned to 26hz.
I was hoping to know which wire is which on the output. I assume there are 4 since it is a DVC sub. Just wanted to know if someone knew the colors of the wires and which wire is what. Thanks!
Newport News, VA
keep searching...that information is out here...I don't know cuz I used a multimeter when I connected my 12s to the signal converter...that didn't last long cuz I took out the sub and put a big amp in there
Lostneye
NY
DVC 4ohms will work but you will lose power. Most of the factory systems are 2ohm and I believe I saw a thread recently with someone asking about a factory sub stamped 1ohm. You will prob gain some with the ported box though but I wouldn't expect to thump with prob 50W to an 8".
I don't know the wiring but I believe you should see the wires going into the box to power the sub.
johnboneske
johnboneske
It actually does work good. I tried it today and works phenomenal actaully.
johnboneske
johnboneske
I will say, it doesn't kick ass by any means, but it is pretty impressive from such a small amp. (Didn't think it had it in it.
johnboneske
johnboneske
Wish someone lived near me(columbus ohio), Id love to show you how good the factory amp works for the sub... You wouldnt believe it...
johnboneske
johnboneske
I think...not 100% sure, the amp is rated for 50 watts/channel @ 4 ohms...may be 2ohms though so at 4 ohms would be about 35 to 40 watts. If you replace the factory sub in the and get a single get a DVC sub.
