Light bar ideas?
spotdog14
Haslett, MI
I'm looking to increase the light output on the front of my vehicle and was wondering if anyone has installed one of those LED light bars either in the front bumper/grill or on the luggage rack area?
I think I saw a picture here once of a light bar installed in the front bumper but cannot seem to find it.
Thanks for any ideas.
Gruz7
North Smithfield, RI
Behind the front grille seems like a decent spot but idk because the 3rd gen grille is a bit thicker than the 2nd gen one
k9education
I would focus on the grille area as most states have laws requiring that off-road lights be covered while on road even if they're powered off. If they're behind the grille, you are far less likely to get hassled/ticketed if the lights are off.
Flexpedition
midwest
Any thoughts about negative effects on cooling?
The way I see it, the 07's+ have essentially 4 openings for fresh air to cool a 2-row radiator, an AC condenser that supports front & rear HVAC evaporators, theres a small power steering fluid cooler, and the transmission fluid gets cooled off (or warmed, depending on how you see it). Remove the grill and you'll see a decent amount of shroud/duct/baffle/fairing geared at directing air specifically. I'm assssuming Ford spent a fair amount of time/3D/R&D/wind tunnel testing or whatever to determine the most appropriate and effecient size/space/volume of air openings, sizing of fans, etc to cool effectively. (the constant whiners here complain Ford does no R&D anyway, so whatever)
Just saying I'd be concerned about blocking 25% to 50% of those openings for the sake of offroad lighting. I cringe when I see a guy running a winter front come springtime too - except when they are in a Dodge, I smile.
k9education
I had the same thought when I was considering adding some lights behind the grille, but thought I was probably worrying about nothing. I figured when/if the time came, I would monitor engine/trans temps via the UltraGauge and see if there was a significant deviation from pre-installation temps.
FWIW, Ford spent $6.4 billion on R&D in 2014. Of course there's no way to know precisely how that breaks down since they don't publish that info.
