Expedition completely shut off, loss of power.
FordGirl1983
Richmond, VA
We're currently researching and troubleshooting from yesterday's issue with my expedition, 99 5.4... Question what causes the power to completely shut off? Does the solenoid can short out, ground out? Can a relay or a fuse blow to make the guages stick (frozen at 50 on the odometer and the rpm stuck at 1000), other needles is down (gas, oil, battery, temp) will attach photo. We was on the highway when it happened, luckily we pulled over. It's most likely is a electrical issue. No power, no lights, no crank, just zippo! The battery seems to be good. Battery is currently disconnected. It was sparking at the battery terminal when trying to connect like it has a short somewhere. Any other information is appreciated, thank you.uploadfromtaptalk1455384804398.jpg
Sent from my SAMSUNG-SM-G900A using Tapatalk
stamp11127
Temple, Georgia
A little spark is normal but a large spark isn't. What type of electrical knowledge and tools do you have?
FordGirl1983
FordGirl1983
Richmond, VA
We have the well known tools like the multimeter. We tested between negative battery terminal and engine block including frame. Getting 12.4 vaults. Seems like it's grounding out.
stamp11127
Temple, Georgia
There is a constant draw on the battery for the memory circuits. If you can measure amps I would do that next but place a 7.5amp fuse in series with the meter.
FordGirl1983
FordGirl1983
Richmond, VA
Ok will look into that. Oh and thanks for closing the thread under the Gen 1 category. I've originally posted here in the Electrical category, I guess I was right the first time lol.
stamp11127
Temple, Georgia
You will normally see abut a 100-200 mA draw once the modules power down. Anything above that to 1A means something is on, above 5A I start thinking multiple circuits are on or short. If a maxi fuse pops without engine start attempt - definitely a short.
FordGirl1983
FordGirl1983
Richmond, VA
Update, I think we found the problem. He said that the battery terminal or starter wire something like that connected on the starter has somehow seized, touched the engine block that caused the shortage. Still not out of woods yet but the repairs will be done soon this weekend.
Just to be sure, is the starter wire is 2 or 4 guage? It's a 99 5.4 Eddie Bauer.
FordGirl1983
FordGirl1983
Richmond, VA
Almost forgot to post the photos of the problem I had before and after the fix. uploadfromtaptalk1455847333097.jpguploadfromtaptalk1455847373460.jpguploadfromtaptalk1455847398496.jpguploadfromtaptalk1455847409911.jpg
FrknStallion54
Midland, Texas
Would such an issue cause the positive post on the battery to become REALLY HOT, then later leak/become soaked with acid? I think I have the same issue as FordGirl1983, but noticed my battery looks just as ugly as I do trying to solve this puzzle...
