Upper control arm ball joints
Gruz7
North Smithfield, RI
Hey guys, so just got done everything with leveling my truck and ran into an issue...
So you know here's what I put on:
New complete struts all around
New sway bar end link
New tie rod end
New upper control arm+ball joints
Had the small issued I had worked out and it was aligned last Friday think 5/6/16... Anyways I drove it for a few days now and when I got out to check everything today after work the New control arm/ball joint I got from NAPA on the passenger side has failed...
It failed in the sense that the rubber housing around the joint came up a bit and exposed the insides and that grey grease poured out everywhere on the suspension... The shops all day they give me free labor and alignment and napa says they'll replace it again but why does this happen? And is napa not selling a quality part? Or is this mainly because of the leveling kit? Or should I be buying a different arm/joint that's more "heavy duty"?
If anyone can chime in its greatly appreciated so I don't keep running into this problem over and over... Also the new arm and joint will be put on tomorrow and alignment in afternoon...
Thanks guys
Edit: Figured I'd attach some pics so you can see what I mean...
bc75ef87f6e21224fd5788011d95c219.jpg12b70f554c7ff7a1b4de9eed45bebe7c.jpg7a1694fdb0172214570978f91315375e.jpg
Gruz7
Gruz7
send it to the company first for replacement...or u can buy it
Yeah I'm getting a whole new arm free from Napa and my mechanic is going to out it on for me again for free and then it's going to alignment for free but I just don't want it to happen again you know? Lol
Gruz7
Gruz7
So the when the upper ball joint boot separated this is the grease I found poured out everywhere... Don't know how all this grease was in there but....
Jb14
Before I changed out my upper control arms I did a lot of research and appear as though Napa was using cheaper china made parts or the lower level moog RK series. I Ended up getting the Moog K series (which is the problem solver series, supposedly higher end) from Rock auto. Note I also ended up getting the Oem Motorcraft lower ball joints from Rock
Gruz7
Gruz7
Yeah since this one is replaced for free I'm going to have to have it put on for now and just hope it doesn't split open again for a few months at least... Eventually I'll have to take a look at those K series from MOOG hopefully if I get those on they'll hold up better with the lift because these napa joints seem to suck
Jb14
So far so good on my uppers control arms I have had on for only a couple months but have put around 5k on them
Gruz7
Gruz7
Also, for an update... The pass side has been replaced, NAPA gave me a part that has the same part number but appears to be very much higher quality.. They couldn't see the difference.... Anyways it has a clip and ring holding the boot so this will hopefully not happen again and I decided to do the driver's side replacement to so I can possibly have better parts on both sides... I'll post some pics when I get a chance tomorrow.
Hamfisted
Ft Lauderdale
How's your front CV boots ? 'Cause that grease quantity and pattern look like a split or torn front CV joint boot, not a simple leaking upper ball joint boot.
-Mike
Gruz7
Gruz7
-Mike
The cv boots appear fine they do need replacing in my opinion... That's what I was thinking when I saw that amount of grease as well but they look ok... When I get the new arms in and get it aligned I'll check the cvs again
