Easy way to turn off interior lights when rear hatch is open.
dewebb
I'm sure it is answered somewhere, but here is an easy way to turn off interior lights when the hatch or window is open. Just turn the knob and pull to remove. Works on hatch or window. 20160808_190021.jpg 20160808_191805.jpg
Newport News, VA
Why don't u just turn the light off at the light by putting in "off " position or turn lights off at light switch...no brainer to me
Mr. 10K
D
dewebb
Unfortunately, it wouldn't work on my 2000 model.
tcwaltz
Niceville, FL
On the 2000 opening anything turns on all the lights inside and the running board lights. I've been looking for a way to do this and this seems easy enough.
Newport News, VA
Well that's the same for my 04...can u not just do as I stated on the rear light or on the dash?
Mr. 10K
tcwaltz
Niceville, FL
You can shut off the cargo light but the rest of the interior lights stay on. Nothing seems to shut off the damn running board lgihts.
Habbibie
Is it Christmas yet?
Chicago
My cargo lights stay on if the window is open even if the light switch is off. They stay on no matter what if the key is on, or they eventually turn off 15 minutes later if there's no key. Playing around with the light switch doesn't effect it what's so ever.
1997SCEBFEX
Northwest Panhandle
mine will stay on for 45 minutes.
used to pull the fuse when tailgating for extended periods of time to prevent battery draw over time.
tcwaltz
Niceville, FL
Now I'm wondering if the switch is a neutral break or hot break. I may put a switch in and mount it on the back panel so when the tailgate is open I can switch it.
Bedrck47
Elizebethtown, PA
For the 2000 model the liftgate and window ajar switches are wired in the ground circuits
z168
Cali
At some point the lights will eventually switch off right? Anyway we can install a rheostat of some sort so we can change the timing? maybe decrease it to 30seconds or something
tcwaltz
Niceville, FL
So, when open the switch makes the ground and turns the lights on. Should be easy enough to add a switch in between the ground and switch to always be open (off) should you so desire.
vnctmrn
CH
old post, but thank you for this tip.
I sometimes leave the rear glass open in the garage for quick loading in the morning. Or just hanging out and tailgating. Had to buy a jumppack because it kept draining my battery, didn’t always want to take out the fuse and frick up my fingernails lol.
