OBD2 code reader
poorboy1964
Riverton Utah
Really didn't know what section to ask this in
I need a code reader what is everyone using or liking? I have an Edge CTS in my diesel am very happy with it, but I mounted it so that it's to much work to take out and move to another truck, to much money to buy a second one.
I've been looking at the Iphone apps and a blue tooth obd2 plug but there are so many of them I can't decide what's good or not if any.
Anyone have one they like or not?
ExplorerTom
I have a ScanGauge in my Explorer. It's kind of expensive and only displays 4 gauges at a time.
In my Expedition I have an UltraGauge. It can display up to 8 gauges and costs much less.
I don't have any experience with the Bluetooth readers. What I don't like about them is that to be able to see the gauges, you need to place the phone in some kind of cradle on the dash. Most of the time my phone is in pocket. But for the price and occasional use, they should work just fine.
poorboy1964
poorboy1964
Riverton Utah
Thanks had not seen the ultagauge that could work I'm familiar with the scangauge do you have to put in codes on the ultagauge for the pids you want?
poorboy1964
poorboy1964
Riverton Utah
it doesn't look like trans temp is available have you had any luck coming up with different codes?
reece146
ON, Canada
For just getting the codes I use a blue tooth obd dongle and an Android app. Cheap, cheap, cheap and works well enough for code reading.
ExplorerTom
For it to display trans temp, you have to pay a little extra for them to configure it to read trans temp. I have mine configured to do so. It's not like the ScanGauge where you can program it yourself to display trans temp.
docraymund
philippines
Use an obd 2 bluetooth adapter from ebay and download the Torque and Forscan app on your android phone and bluetooth capable laptop. You can display gauges, graphs etc. with a little practice. And Forscan can bleed your ABS system and diagnose your PATS system.
poorboy1964
poorboy1964
Riverton Utah
Thanks I have have a Iphone last I looked the Torque app was only Android, I remember reading about the forscan a while ago I'll check back into it
Habbibie
Is it Christmas yet?
Chicago
I have one of those actron pocket scan readers, had it for 10 years now since 96 & still works. Only reads codes though that's it.
poorboy1964
poorboy1964
Riverton Utah
Habbibie looks like a good reader still has good reviews might be a good way to go, carry a reader like that then set up for the forscan for like data,,,
chipete
appleton, WI
I purchased the cheap ebay elm327 mini and it won't connect to my 98 Expedition but works on my chevy . And yes I'm getting power to the elm327 . Any suggestions people!
Sent from my SM-N900V using Tapatalk
poorboy1964
poorboy1964
Riverton Utah
if your sure that you have power then i'm not sure, I know in the F250 mine stopped working it shared the fuse for the cigar lighter that had blown
tcwaltz
Niceville, FL
I have a Bosch that does ABS as well. I think I spent 119 for it. I should have gone up a step to get the other functions but it works for what I need. I had purchased a windows app with a bluetooth dongle but had more trouble with that than it was worth and sent it back. If you work on vehicles alot just spend the money on a good hand held. They are fast generally work quite well.
abyars
AL
This is a great thread. I've been pondering the same question. Thanks for everyone's responses.
Chris Galbraith
Pleasant Grove, UT
I have both a generic Android bluetooth dongle using Torque Pro and the VeePeak wifi for iphone using OBD Fusion. Both are similar and I like them both. They both are very adaptable for guage displays and have the ability to be used as a HUD.
poorboy1964
poorboy1964
Riverton Utah
Just read about the Bosch different models I liked it looks like an easy interface
poorboy1964
poorboy1964
Riverton Utah
Thanks Chris do you find anything lacking with the OBD Fusion software? I will look into that one
