06 rear wheel bearing replacement
Dieselboy2343
Vermont
Got a 06 expedition 4x4 and trying to get the left rear wheel bearing off but can't get cv shaft to come out. Tryed 3 jaw puller and pb blaster and hammer. Trying not to damage shaft so looking for ideas or pics on how to get it out.
Bedrck47
Elizebethtown, PA
Go to youtube and search for videos on replacing the hub bearing There are a few good videos there
D
Dieselboy2343
Vermont
Yeh I tryed finding some but most of them just show them popping right off of course mine I'm sure is rusted right in
MikeA
Are you having a problem getting the cv joint shaft to slide out of the hub bearing?
Got an air compressor and a air chisel with a punch tip?
MikeA
If no air ,
Put the cv nut back on until it is flush with the end of the shaft, take a socket , impact socket prefered, that is slightly smaller in diameter the the shaft end, hold socket to shaft and hit with a big hammer until the shaft loosens.
The cv nut flush to shaft is just in case you slip with socket , prevents damaging cv shaft threads
Does not take much to get the shaft to move.
Use a slide puller to remove hub, after you unbolt it first, obviously
D
Dieselboy2343
Vermont
Yeh I can't get the cv shaft to move out of the bearing I did try the air hammer and chisel bit too. Sorry I forgot to mention that. It still did not want to move at all. I'm wondering if I will have to torch the bearing off.
Bedrck47
Elizebethtown, PA
All I will say is keep trying they can be a PITA to remove
If you looked at the videos the one I looked at there was a nice bit of rust on the shaft. When you finally do get it off use a wire brush and clean up the shaft then apply a thin coat of lube on the shaft to help prevent rust
MikeA
So true on the pain in the ass part, air chisel usually works, but when there stuck, need to break out the big hammer and teach it a lesson.
Without smashing a hand in the process.
Bedrck47
Elizebethtown, PA
Or missing and breaking something else
MikeA
I don't see how he is going to remove the hub with a 3 jaw puller, needs a slide hammer at best.
Could use a chisel and work the hub off, but that is taking a chance on gouging seating/mating area .
Bedrck47
Elizebethtown, PA
That's what happened in the video I looked at.
Maybe use some more PB Blaster and let it sit over night or maybe a little heat on the bearing
One thing he could try is to put the bolts about 1/4 to 1/2 way in and try hitting them from the back side May just cause the bearing to move somewhat
I know that's in a hard to reach area
MikeA
I have never used PB blaster or WD40 to remove hubs, brute force usually good enough to get them apart.
His best bet is a slide hammer, makes hub removing alot easier.
Next is the hammer and chisel, have a metal file handy just incase a gouge happens. Just going to take alot longer to remove hub.
D
Dieselboy2343
Vermont
My first attempt was hitting the end of the shaft with a hammer, putting the nut on to protect threads but the end of the shaft flattening out to the point I could not get the nut off without grinding the end down. So that's why I stopped just beating it but I will try the nut and socket trick and hopefully get some kind of movement
MikeA
That is why I would use a impact socket, putting the cv nut flush and hitting shaft with the hammer will mess up the shaft threads and or nut.
Learning experience for next time.
Use a impact socket, there beefier and can handle the abuse your going to give it, when you hammer away, I use a 4lb sledge hammer for stuck cv shafts
Make sure the impact socket is smaller in diameter then cv shaft end, cv nut flush to prevent thread damage , just in case.
Sounds like you got one of those pain in the ass cv shafts. PB blast it really good on the back side , if you can get it to go in
MikeA
Did you unbolt the hub?
If not, do that, then try and remove the hub, get the hub to slide out about a 1/4", then try the socket and hammer, see if the cv shaft moves.
This will relieve any binding in the cv joint, or lack of slack in other words.
D
Dieselboy2343
Vermont
Yes I did have it unbolted and I tryed air hammering where the bearing bolts up to try and spin it a little but didn't want to move.
MikeA
Ok, start removing the hub, as I mentioned , I think the cv is binding up, should not be this much trouble removing.
Get the hub out about 1/4" or more ,that should relieve any binding or lack of slack in cv, use socket and hammer on cv shaft, should start to move.
MikeA
Once the cv shaft starts to move, you should be able to slide out hub and knock the cv shaft out .
