Wheel Bearing? Or worse?
cjray03
Washington
HI, I searched and found several threads on wheel bearing noise related stuff. My problem is my '99 EB 4x4 has a low whomping noise coming from what seems like the right front area. I jacked it up and turned and shook the wheel. it's tight and when I turn it I can't tell if the noise is coming from the wheel or further up in there. I guess my question is....what is further up in there behind the tire that can cause a low rubbing or whom. whomp, whomp sound? When I drive it the noise is pretty continuous at any speed, what I mean is it doesn't get faster or slower with speed, except when I am going left around a curve, it quiets down. Oh, I guess I should say that the EB has 275k+ miles on it, and I have no idea when or if any bearings have ever been changed.
Fastcar
Army
FL
Could very well be a wheel bearing, turning left shifts the weight. Take it apart and see what you have before it get's worse.
C
cjray03
Washington
Thanks, yeah, it was the bearings, shot. Not too hard to replace though, except getting to the end of the ABS sensor wire, that took a bit of doing.
16exped
KS
You changed both wheel bearings correct? If one is bad, the other one isn’t too far behind.
