2015/2016
mdntblu
mdntblu
Corona, CA USA
So I'm trying to figure out how to get Apple Carplay working on my new 2016 Exp with Sync 3. I thought it was supposed to support it. It doesn't seem to be updated to the latest version. Says current version is 2.0 and I did the automatic system updates and it doesn't do any update.
ExpeditionAndy
Fort Wayne, Indiana
Brad,
Check out this link: https://support.apple.com/kb/index?..._searchbox_main&feedType=suggested&position=1
It says that you first have to be an an area that supports car play. I get the screen you have pictured above when I connect by cable.
I find nothing but radio stations and audiobook players in the App Store that say the are carplay apps. Since I have a radio and satellite in my truck I can't ever see using any of them.
It looks like carplay is just using Siri through your truck's system.
Set up CarPlay
  1. Make sure that your car or stereo supports Carplay.
  2. Plug your iPhone into the CarPlay USB port. The USB port might be labeled with a CarPlay icon or a smartphone icon. If the CarPlay Home screen doesn’t appear, select the CarPlay logo on your car’s display.
    • If your car supports CarPlay over a wired solution, plug your iPhone into the USB port of your car. The USB port might be labeled with a CarPlay icon or a smartphone icon.
    • If your car supports wireless Carplay, press and hold the Voice Control button on your steering wheel to set up CarPlay. Or make sure that your car is in wireless or Bluetooth pairing mode. Then on your iPhone, go to Settings > General > CarPlay > Available Cars and select your car. See your car's manual for more information.
  3. Make sure that your car is running.
  4. Ask Siri for what you need. You can do this in a few ways:
    • Touch and hold the Home button on your iPhone until Siri appears on your stereo display. Then ask what you need.
    • If your car has one, press and hold the Voice Control button on your steering wheel. Then ask what you need.
Get help
If CarPlay doesn't work like you expect, here’s what you can check. After each step, try using CarPlay again.
  1. Make sure that Siri is turned on.
  2. Restart your iPhone and your car. Depending on your car, you might see the CarPlay Home screen when you turn it on. If you don't, look for the CarPlay logo on your car’s display.
  3. If possible, connect your iPhone to a different USB port in your car.
  4. Try a different Lightning to USB cable. Make sure that the cable is certified.
  5. Update to the latest version of iOS.
  6. Check your car’s manual for help. You might need to install firmware updates for your stereo.
Learn more about CarPlay and driving and navigating safely.
ExpeditionAndy
Fort Wayne, Indiana
Here is some more info. Can you play your music from your phone on your car entertainment system? If you are it is working.
Get help connecting your iPhone, iPad, or iPod touch with your car stereo
You can connect your iOS device with a compatible car stereo using Bluetooth, a USB cable, or CarPlay. If you can't pair or connect your iOS device with your car stereo, or you don't hear audio playback, learn what to do.
If you're using Bluetooth
  1. Check your car stereo's user manual for how to pair with a Bluetooth device.
  2. On your iOS device, swipe up to open Control Center, then tapios8-bluetooth_icon.pngtwice to turn Bluetooth off and back on.
  3. Restart your iOS device.
  4. On your iOS device, unpair your car stereo. On your car's display, unpair your iOS device and any other devices. Restart your car and your iOS device, then pair and connect again.
  5. Update your iOS device.
  6. Install any firmware updates for your car stereo.
  7. If you still can't connect, contact Apple Support.
If you're using USB Playback
  1. Restart your iOS device and your car.
  2. Connect your iOS device to a different stereo USB port (if you have one).
  3. Try a different Lightning to USB cable.
  4. Update your iOS device.
  5. Install any firmware updates for your car stereo.
Try playing audio from a different app. If you can't play audio from a third-party app, contact the app developer for help. If you can't play audio from an Apple app, contact Apple Support.
If you're using CarPlay
Many newer model cars support CarPlay—providing a safer way to use your iPhone in the car. To use CarPlay, you need an iPhone 5 or later with iOS 7.1 or later. Some features (like turn-by-turn navigation) aren't available in all regions. Learn more about how to set up and use CarPlay.
If your car supports wireless CarPlay, touch and hold the Voice Control button on your steering wheel to set up CarPlay. Or make sure that your car is in wireless or Bluetooth pairing mode. Then on your iPhone, go to Settings > General > CarPlay > Available Cars and select your car. See the owner's guide for your car for more information.
Information about products not manufactured by Apple, or independent websites not controlled or tested by Apple, is provided without recommendation or endorsement. Apple assumes no responsibility with regard to the selection, performance, or use of third-party websites or products. Apple makes no representations regarding third-party website accuracy or reliability. Risks are inherent in the use of the Internet. Contact the vendor for additional information. Other company and product names may be trademarks of their respective owners.
Published Date: Dec 6, 2016
ExpeditionAndy
Fort Wayne, Indiana
This may be obvious and if it is I'm sorry, but you have to connect your vehicle to your home or office WIFI in order for the update process to work. If you cannot not connect by WIFI you will not get any updates and the dealer will have to do it for you.
mdntblu
mdntblu
Corona, CA USA
Can you go to Settings on your Sync 3 and find the Update area and see what version Sync you have? I have mine connected to Wifi and it says I am on version 1.0.
So you get this screen when you connect your phone : maxresdefault.jpg
What I mainly want it for is Maps and Messages. I get apps to load on my Sync 3 like Spotify and Ford Pass and stuff but I don't get this screen shown above. I guess it's only Sync 3 in 2017's or something.
Moderator
2016 Edges did not have a hub that had the Apple certified chip in them. I swapped my hub for a supported one. My guess would be that the 16 Expy is the same way. If you are at 2.0, you have the software level you need. Verify you see Android Auto in the Settings menu. Do you see a CarPlay icon beside it, if not, your hub doesn't support it, and will need to be swapped.
Moderator
You won't see this until you accept the connection on your phone. You will see the top of the screen on your phone go blue, and CarPlay come up on the screen.
ExpeditionAndy
Fort Wayne, Indiana
I think I have version 2.0, that's what the Ford Owner site says. I'll check tomorrow and post here. (You can always take it to the dealer and they will do the update at no charge.)
Yes my screen looks similar to that, I have some different apps.
I get messages but I have never tried the maps because I have Navigation. (I was really hoping that Waze would work because we put that on the iPad and use that for navigation because of knowing where the trouble spots are, and where the cops are sitting.)
This is what the Ford Owner site said:
Date Confirmed: Dec 15, 2016
Version:SYNC3 v2.0
Hide details
HB5T-14G381-AJ
The new version contains the following updates:
  • Updated voice recognition engine.
  • Bluetooth phone, media, and Wi-Fi improvements.
  • Navigation user interface improvements (if equipped).
  • Android Auto for supported devices.
  • Apple CarPlay for supported devices with hardware upgrade.
Moderator
Ford is not updating any 16's from 1.0/1.1 to 2.0/2.2 that I am aware of at this time. Not sure what they are waiting for. Lots of talk on the F-150 and Edge Forums about it. A guy named Jason has access to the updates and has shared installs that will do the update. 2.2 is technically the highest, and what the newest Fords coming from the factory have installed. Anything 2.0 and above supports AA and CarPlay. CarPlay requires a USB hub with a certain Apple certified Hub. Most 16's, at least Mustangs, and Edge's that I am aware of for sure need to swap the Hub to get CarPlay. It makes sense that the 16 Expedition would be the same.
I have the install files to take any 1.0/1.1/2.0 to 2.2 if anybody needs it. I worked with Jason on testing the install. I have done several friends with no issue.
ExpeditionAndy
Fort Wayne, Indiana
Thanks for the info LokiWolf. I'm going to check my version number today and see if it is at 2.0 I'll see if I can update it through WIFI. My build date is 12/15/16.
Moderator
No updates OTA for Ford vehicles that I have heard. Some Lincoln owners have reported OTA, but no fords that I have heard about. Delivery system is there, but ford is holding back. If you have a 17, you have 2.0 or above, and a compatible Hub.
ExpeditionAndy
Fort Wayne, Indiana
I just talked to Sync chat, and they said that 2.2 hasn't been released for my vehicle. I have the compatible hub and I can access the apps on my phone when I'm plugged in. I can use Siri over Bluetooth.
Moderator
Yep, Exactly what I said. Sync Chat Honestly knows less than many of us about their own product. I have done more Updates and more research than the 3 dealers I have talked to about it. 2.2 WILL install on your vehicle, as it is installed on my Wife's 17 Limited EL, and 2 friends Expeditions. You just need a flash drive 2GB or more, and a download link. With that said, going from 2.0 to 2.2, only gains You small tweaks in the interface and nothing significant.
ExpeditionAndy
Fort Wayne, Indiana
Where can I find the download link?
mdntblu
mdntblu
Corona, CA USA
Where do I find this upgraded hub. Mine won't go past 1.0. I really had thought by watching videos and entering my year and model in on the syncmyride website that it showed Carplay was available. I would of got a 2017 if I had known that. Argh. Sometimes I hate technology. LOL
Moderator
So, Your Sync 3 version is 1.0?
