What's it cost to run A/C with or without radio per hour just waiting around?
I know in econobox it's cheap, like 1/4 gallon per hour even in Nevada desert heat.... but what about our V8's??
V8 idle fuel efficiency
I would say that the fuel efficiency at idle is a dumb question You are getting 0 MPG's at idle Not very efficient But then again I guess it is important to some people to know just how much gas they are wasting by sitting and letting the vehicle idle
Plus to many variables to get a true answer Idle RPM's Fuel Pressure etc.
But if its a matter of life or death to know the answer then I would suggest that you invest in a precision flow meter to get a accurate reading
Or if its also that important to know the answer then just don't sit and idle and waste fuel
It's not a diesel. It's really not a great vehicle to run long at idle.
I have a scan gauge 2 on my 2007 Expy. I was curious about this too. I have found it runs about 7 tenths of a gallon an hour at idle.
better get a second job so you can afford the cost
But then again now you know what his expy uses but you still have no idea what yours uses You wont know unless you check your expy could be more or less.
Does it bother you that I see through your BS Is it really that important that you had to ask someone to figure out how many gals per hour you waste sitting at Idle Or you just to lazy to figure it out yourself. Invest in a flow meter then you would know what your expy uses Not what someone else's expy uses
