oh deary me
another expert
expert? surely you are not resorting to passive name calling right now.
rather we should be discussing why these supposed tests literally don't prove a thing
oh deary me
another expert
i commend your position at some kind of axle testing facility, however these supposed tests do not prove anything.
once again i need to repeat myself - the differential is a precision component. there is no way any of those "indestructible" differentials are going to last on the road more than 5,000 miles after running those tests. its quite silly of you to think these tests would even prove anything. yes, the housing wasn't completely destroyed, so what. this proves nothing. it seems that you are really going out of your way with poor facts and data. no offence
This guy is an idiot... seriously...
You may want to leave mechanical activities to mechanics... wow... I mean, you tried to jack your truck off the ground, something my 12 year old could do with confidence, and you made it "crooked".. your words not mine. And you want to question people's experience and knowledge because you lack understanding in structural integrity of a friggin' differential. Amazing.
this "supposed" test is not just to test the housing. It is to test the axle assembly as a whole. After the test, the parts are removed, inspected many ways in the metrology lab including CMM and other analysis
Yes, for how long? Lets not pretend this is anything significant either please.sometimes, the axle is put on a vehicle and ran through a battery of on the vehicle testing.
By gosh you are full of excuses.They don't just see if the axle housing is bent and throw it away. These tests cost hundreds of thousands of dollars by the time everything is complete.
So, my Hayne's manual made no comment about where to use a floor-jack to raise the rear end for a brake change, so I raised it from the rear pumpkin.
Now I checked the owner's manual and it says never to do that.
Seriously? That's the most convenient place to jack up the rear by 1000%. The owner's manual actually suggests to jack up a rear axle side. I'm surprised one rear axle tube is that strong to handle most of the weight of the back half of the truck! Plus, that seems like a safety concern to jack up one side, place a jack-stand, let down and then jack up the other side (with all the tilted weight on one jack-stand) until the other jack stand can be put under the new side.
What's the concern with the rear pumpkin? Would a piece of plywood between the jack and rear pumpkin resolve any concerns about jacking under the rear pumpkin? Or, is the pumpkin so weak that it really shouldn't support the weight of the rear of the truck?
First off the HAYNE'S manual is a POS and not a Ford manual The Ford Owners manual that you are referring to is giving directions about changing a rear tire NOT LIFTING THE WHOLE REAR END. That information was in the ROADSIDE EMERGENCY SECTION.
You may be correct that you are ONLY 19 But your acting that you are an EXPERT compared to all of the experience that has been offered to you Maybe its time that you get away from your better than those that know more than you GO back and read what you posted in the past
"I kind of need this info as a crutch due to my inexperience"
Time to remember this and keep your mouth shut and listen to those that know more than you and maybe JUST MAYBE you will learn something.
BUT THEN TO SHOW JUST HOW MUCH BS YOU ARE LOOK TO YOUR PROFILE WHERE IT SHOWS Jan 1, 1982 (Age: 35) NOW SAYING YOUR 19 when your profile says 35 ONE OF THOSE IS A LIE and that about sums you up.
