Hey all,
First off, I am very much an rank amateur when it comes to vehicle repairs and diagnosing problems. I need all the help I can get, believe me.
OK, I have a 2003 Eddie Bauer with 110K on it. About 4 years ago I had a couple codes come up about 6 months apart and when I took it to the local parts store they told me that the codes meant I had a problem with one of the cylinders and needed a replacement of the Ignition Coil I had a family member do it for me cause I had no clue. Both times it cleaned it up and it ran fine.
In the last year, maybe 2, every now and then I will notice a slight miss when accelerating from about 15 mph to maybe 45 mph. It never happens when I am overtaking a slow vehicle or when I really press on the gas pedal. It will miss just a slight bit during that acceleration and then stop and sometimes it will repeat the next time I am at that speed and am speeding up to be in the normal traffic flow.
It hasn't happened for many months but today I was on about a 30 mile trip across town and about 1/3rd of the way when I left from a light, I noticed the slight miss again. As usual it will just miss during that slight acceleration and quit. Today it done it several times. On the trip back however, it only did it maybe 1 or 2 times and that was it. I could get it in tomorrow and drive across town or down the road to McDonald's and it might not do it again for 6-8 months, maybe a year. Today is the first time I have felt it in probably 8 months or more.
There are NO CODES being triggered.
I don't know if this would be a factor, but right before this started happening, my tank was on E and I pulled in to get gas. I don't know what kind of gas this station uses and whether it's good gas without much corn alcohol or not.
I have thought that I should probably replace all 8 of the ignition coils and plugs, but I can't do it and I don't know a reliable mechanic here that I could get to do it without being charged a TON for it. I think FORD wanted like $750 to replace them all, if I remember right from 4 or 5 years ago when I talked to them. My family member that did it for me last time is in poor health and he just can't do things like he could.
Can you all give me an idea of what might be the cause of this intermittent slight miss? Could it be the gas this time? Is there any significance to it happening only at low speed acceleration rather than when it has a stronger load on the engine like when overtaking a car going 55 mph?
Any ideas and suggestions would be appreciated. Thank you all kindly for your time and any help you care to give me.
Larry
Larry
