please help...and don't laugh (lifting an expy)
mmrseed
Huntsville
ok, so I have a 2wd 99 expy with a fabtech 7.5" lift on it and I want 2-3 more inches without going the body lift route....yet. :) What are my options? I keep hearing about the leveling kits but how does that work on a suv which doesn't have the uneven rake of a truck with a bed? Will that make my front end look higher than the rear? I don't really understand suspension on trucks as I've always had mustangs (still do) and all I ever needed to know is that springs lower a car 1-2 inches...and that's it.
Also, my rear tires (35" bfg at) sit 2 inches closer to the the front lip of the rear wheel well than the rear lip. Does that mean I have a serious caster problem? I always thought camber and caster are front suspension issues only. The reason i ask, is that seems to prevent me from having 37" with this lift, forcing me to keep 35" for clearance. thanks.
Sincerely,
Confused
M.Sowder
Utah
Sincerely,
Confused
Put a solid axle and bigger leaf springs.
nvycrmn
Springville, IA
not sure why you would want that much lift on 2wd but hey, bigger is better. you gonna convert to 4wd eventually?
mmrseed
mmrseed
Huntsville
Funny, I'm not THAT confused about suspension issues. Coil springs at all corners, it's an suv, not a truck and it is a solid rear axle. My reasons for wanting to lift a 2wd are the same as wanting to lift a 4wd ....I just want something that looks a little cooler. A moderate lift (which it has now) looks too close to stock and I don't care for lowered suv's too much so....there you have it
mmrseed
mmrseed
Huntsville
That is true, but yours looks quite higher than mine I believe because it was a 4x4 to begin with which sits higher stock than a non 4x4, right?. A 2wd like mine with a 7.5" lift looks like a 4x4 with a 4 inch lift. If I could get 3 more inches (on my truck) I would be happy
Lane24
technical advisor
Alberta , Canada
Pics please..... I'd like to see this 7.5 inch lift that doesn't look like a lift. Sounds like a lot of height to me!!! ...My 5 inches makes it look like a monster next to other Expy's. Especially if you are running 35's. Must be huge. I'd like to see it.
Lane24
technical advisor
Alberta , Canada
That's awesome man. I see what you say though. Maybe doesn't look like 7.5 should. But I like it a lot!!! Nice truck!!!
tonydiv
technical advisor
Middle River, MD
I think that it has the perfect proportion of tire size and lift height.
What size tire are you thinking of moving up to?
nvycrmn
Springville, IA
first i would like to say, nice truck! obviously im a fan of black, thats why im blacking out my interior as well (expy teardown thread in general discussion).
"My reasons for wanting to lift a 2wd are the same as wanting to lift a 4wd ....I just want something that looks a little cooler." Thats not the reason most of us lift a 4x4. we do it for functionality offroad. im not saying you dont, but with 2wd, you are still limited to the performance of your tires and your driving ability. im not knocking you in any way cuz even with 4x4, without good driving skills, 4wd just gets you stuck faster!
and ur right, ur lift doesnt look much higher than a standard 6" lift kit. i suppose a 3" body should do the trick for ya, and relatively cheap. i dont suggest the full throttle. i have heard bad things about their setup. here is a pic of my expy with the 4" rancho on 35" toyo.
http://i990.photobucket.com/albums/af25/nvycrmn/CIMG0216.jpg
mmrseed
mmrseed
Huntsville
Thanks for the compliments. I would like to run 37" and I really want 3 more inches minimum or up to 5 more maximum. Right now I have the 35"'s on it and I'm no offroader in this thing (not seriously but i play around in muddy undeveloped tracks locally)...not until I get more done to it chassis wise if you know what i mean. It's no beauty queen but I am honestly one of the guys more into lifted looks than I am functionality because it's function as is.
Funny story ...the whole reason I got the lift in the first place is i was walking out to my truck in the parking lot on day and saw a diamond engagement ring wedged in my tire tread. It was still in perfect condition. I got it cleaned and appraised and got $3000 for it and lifted my truck the next day without even thinking about it
97_edition
I agree nice find! I would have done the exact same thing if my expy found a diamond ring.. BTW, Nice looking 2wd mmrseed.
walnuts4x4
Watertown, NY
i would never do full throttle or whiplash... unless it is a pure show truck trailer queen... they are big but front end of an IFS will not withstand it..and most of those trucks with those lifts take out the front driveshaft... hell my truck's front end doesn't like my lift.. cant keep ball joints in it.... but a 3" body lift on that should easily let you clear 37s if you dont go to wide of a tire and rim.... but def like your expy... like i always say I am jeaslous of black!
walnuts4x4
Watertown, NY
well first set was over a year and new ones I just put in only lasted 2 months... the grease boot blew out... and no i didn't over-grease them.... so i just keep them clean and put in grease every other a month... or the fact they might just be cheap ball joints from Autozone...
dgray69
upstate ny
auto zone, dam boy you are cheap, any criticial parts like that i always go to napa, way better quality, i bought a set of unversals at auto zone for my jeep when i had her, they were alright on the road, but that afternoon i went wheeling with some jeep club freinds and all hell broke loose, less than 5 minutes into a simple trail ride, new universal exploded, grrrr was i pist
tonydiv
technical advisor
Middle River, MD
Not to completely hijack this thread, but I've been looking in to a set of tubular A arms with replacable "uniballs" which are supposed to be far stronger than regular ball joints. I just started researching this and I'm not very familiar with them. I'm also not sure if they have uniball lower joints. Anyone?
