2017 Raptor Wheels
Triplet Dad
Cypress, TX
Do the TPMS monitors still work? I put newer 20" F150 wheels/tires on my '07 and they are on a different frequency.
J Ski
3.5plati
VA
Needed new wheels, but I found a deal on a brand new set of 2017 Raptor wheels and tires. Fit perfectly, threw a 1/4" spacer under the rears so that they matched the front.
This is with Ranch quicklifts in front and the rear air adjusted for ~1.5" lift.
Looks really good actually.
Adieu
SoCal
Looks BEEFY
Do 0.25" spacers really produce any visible change??? I thought the tiny spacers were pretty much solely bandaids for solving unforeseen rubbing/suspension clearance issues on aftermarket setups
Z
Zach94
Batavia, IL
What size tires, 315/70/17? Any rubbing? Did you have to trim anything?
Yes, stock Raptor 315/70/17 BFG KO2s. No rubbing at all, no trimming either.
Looks BEEFY
I bought .25” & .5” spacers in case I ran into any clearance issues before installing these. I had no clearance issues without spacers, but the rear tires were about .25” set inward of the fender relative to the front tires. That’s something that always bugs me about stock Expeditions. So I tried the .25” spacers and it looked better, plus, the stock hub-centric flange still stuck out past the spacer so I kept them on there. Definitely don’t need them, but I had them, and it was a little improvement aesthetically.
J Ski
3.5plati
VA
Where’d you get your spacers?
ACE 71
CA South Bay Area
Looks great! I have Raptor wheels and tires on my ‘09. Preparing to lift and Raptor wheel my 2017. Explain the 1/4” spacer? Thanks!
