What are these
J Ski
3.5plati
VA
IMG_3267.JPG can these be accessed and changed to LED? Little amber lights on far outside of the headlights. Just switched out the front turn signals to amber LED (went with JDM ASTARS for these) and was wondering about these little guys
ExpeditionAndy
Fort Wayne, Indiana
View attachment 21860 can these be accessed and changed to LED? Little amber lights on far outside of the headlights. Just switched out the front turn signals to amber LED (went with JDM ASTARS for these) and was wondering about these little guys
The ones on the outboard sides are already LEDs. Only the turn signal bulb closest to the grille is incandescent.
ExpeditionAndy
Fort Wayne, Indiana
J Ski
J Ski
3.5plati
VA
ExpeditionAndy
Fort Wayne, Indiana
You doing resistors or do you have Forscan?
I have the resistors and FORScan, I'm going to try it without resistor first and then If I have trouble I'll install them. I really don't want to turn off the bulb out feature, at least not as a first resort. I'm going to put shrink tubing over all of my connections and seal the ends with silicone.
J Ski
J Ski
3.5plati
VA
I hear ya. I'm at that crossroads now on whether to invest in a BT OBD2 tool or resistors. I personally would rather not cut into factory wiring if I dont absolutely have to. Let me know how it goes for you
jeff kushner
North of Annapolis
One thing's for sure Andy....your alternator is going to live forever considering on how much you've dropped the lighting load by switching nearly every bulb to LED!
jeff
ExpeditionAndy
Fort Wayne, Indiana
I'm a little hesitant to do that as well which is why I want to try it without putting the resistors on first. If I could find LEDs with resisters built in that would have been ideal.
ExpeditionAndy
Fort Wayne, Indiana
jeff
I wonder about that Jeff. I wonder if adding back resistors just doesn't add load back to the system - afterall a resistor is just a heat producing device that uses current. :confused:
Gary Waugh
Princeton, TX
The resistor is wasting a lot of current, but only when the indicators are turned on, but in reality you will not be saving any power over the incandescent bulb, just have a longer lasting bulb (LED's last longer than incandescent). Of course if you don't need the resistor then you are saving some power!! But let's face it, we are changing to LED's for the coolness factor not power saving!! :angels25:
Gary
ExpeditionAndy
Fort Wayne, Indiana
Gary
Very true Gary!
I'm hoping that I can get away without having to use the resistors. I can turn off the bulb out feature with FORScan but I'd rather not do that.
