Subwoofer doesn't work
sparkone
Louisiana
I have an Eddie Bauer Expedition ,with the Mach audio system, I cannot find the reason why the subwoofer is not working.I took it out, replaced the connection, I don't think I'm getting power back there all together. I know the 25a fuse under the dash is for the audio, and it is fine, but they have other fuses that are also for the audio HELP PLEASE!!!
nvycrmn
Springville, IA
this is a great questions. cuz mine just stopped working too. i have the same system in mine.
ELVATO
Orlando, FL
On a 2000 Expedition, there are 3 things listed that could cause an inoperative sub:
-the sub itself
-the sub amplifire
-the wiring going to these
To start things off, disconnect the plug going into the amplifire. Measure the voltage from pin 1 (dark green/violet wire) to ground. Is there voltage?
S
sparkone
Louisiana
I checked for power,and it has power. I plugged the speaker up in my house to see if it worked, and it does. The plug coming from the amp to the speaker is really loose, I tightened the connection, and still nothing. Any advice, and what should be reading coming from the amp to the speaker
KWT2000
NINE MILE FALLS
you can check the wattage output and see if you get a reading my money says the amp is bad
