Expedition Ecoboost Tune
jdeshong
Has anyone here tuned there 2015+ Expedition Ecoboost? I just ordered the Livernois 93 Performance tune which gives +80rwhp and +80lbs torque at the wheels. I have the tuner in hand, just waiting for my tunes to arrive in my email.
AllBoostNoEco
GA
Sure have. I have 3 different tunes from 5-Star: 87 Performance Tow, 87 Performance, and 93 Performance.
Basically run the 93 tune since I bought my truck.
Worth every penny IMO.
07xln
Dallas
Curious what kind of gains you got from your 5 Star tuning? I'm thinking about getting one of their SCT tuners for my 17. I only run 93 octane so the two other tunes I'll probably never use.
Also I see you got a tow tune but I don't see any "tow" options on 5 stars website. Only economy and performance tunes. I do a lot of towing so that's why I ask
AllBoostNoEco
GA
I can only go off their dynocharts, which shows their F-150 4x4 with 3.73s making 250hp and 300 ft-lbs stock. Their 93 performance tune shows 320hp and 450 ft-lbs peak. All figures at the wheels. But the real win is that the tuned one doesn’t drop below 300 ft-lbs until 5300 rpm.
It sure feels like the numbers are spot-on. My truck feels like a hot rod compared to my wife’s stock Platinum even with 35s.
I don’t remember where I found the tow tune, but it was there when I ordered my tunes. I didn’t think twice about it because I had the same tunes on my F-150 except my 93 tune was their ‘Race’ tune.
07xln
Dallas
That's quite a jump especially on the torque. That would make towing a whole lot nicer. I'll get with 5 Star about the tow tune
Thanks for the help
bobmbx
Are you sure about the 250hp? My 2017 XLT makes 365hp off the factory floor.
Engine Specifications
Drive type Rear-wheel drive (std.); Control Trac® Four-wheel drive (opt.)
Engine type 3.5L EcoBoost® V6 with Ti-VCT
Transmission 6-speed automatic with SelectShift®
Final drive ratio 3.15 (std. 4x2 Expedition); 3.31 (std. 4x4 Expedition & 4x2 Expedition EL)
3.73 (std. 4x4 Expedition EL, opt. 4x2 Expedition EL & 4x2/4x4 Expedition)
EPA-Estimated Rating
(Actual mileage will vary) Expedition 4x2: 15 city/ 21 hwy/ 18 combined mpg
Expedition EL 4x2: 15 city/ 20 hwy/ 17 combined mpg
Expedition 4x4: 15 city/ 20 hwy/ 17 combined mpg
Expedition EL 4x4: 15 city/ 19 hwy/ 16 combined mpg
Horsepower (SAE net@rpm) 365 @ 5,000
Torque (lb.-ft@rpm) 420 @ 2,250
Compression ratio 10.0:1
They are talking at the wheel not the crank. Massive power is lost through the transmission, driveshaft, differential, CV axles by the time you get it to the wheel.
bobmbx
I got curious. The following graph is directly from the 5Star website http://5startuning.com/got-2017-f150-3-5l-v6-ecoboost/and shows a 2017 3.5L EB F-150 dyno "@ Wheel SAE J1349" (I admit, I have no idea what that is; I'm assuming its a standard test procedure for power testing "at the wheels"). stk-87-vs-93-perf-V3.jpg
A quick review of of chart shows an unmodified 3.5L EB pushes in the neighborhood of 325-330hp (peak power) at the wheel.
AllBoostNoEco
GA
The 2017 has the advantage of improved output (375hp and 470 ft-lbs) and the 10-speed. Not to mention it doesn’t state whether it’s a 4WD or not. I’m guessing not with that output.
This is a 2014 with 4WD and the EB. It’s also most directly comparable to the 15-17 EB. It’s a 31% powertrain loss, which isn’t abnormal.
A 375-hp engine losing less than 20% drivetrain (like the 2017 chart) is pretty remarkable. That 10-speed must be amazingly efficient, and/or the 375 is a bit of a lie.
Goff69
