Expedition Ecoboost Tune
Just change the blinker fluid and your truck will be gobs faster.
Be careful with that one. If you don’t de-magnetize the floor mats before you change your blinker fluid your backflow preventer is prone to an overcharge. You can say goodbye to your spark plug resistors and muffler bearing at that point.
ExpeditionAndy
Fort Wayne, Indiana
Another thing to be careful of is if the base plate of pre-famulated amulite becomes detached when adding blinker fluid, the ambifacient lunar waneshaft can cause side fumbling in the unilateral phase detractors.
07xln
Dallas
Just ordered my SCT from 5 Star. Got a bunch of trips lined up beginning of the year where I'll be pulling my toy hauler with SxS in it. I'll be right at max towing capacity. Looking forward to that extra power
Moderator
Well aren’t you an optimist, that’s rare but can happen, way to look at the bright side (sarcasm). If that plate of amulite becomes loose or worst case brakes off it can make it’s way through your hyberbulatized heat exchanger system through to your Kuhneutson Valve and clog it opened allowing liquid unobtainium into the crank gear liner, effectively destabilizing the demystifyer causing your full port alternator to overcrank. And as if all that is not enough I’ve seen it cause a blown Johnson Rod. Yep, do your maintenance folks.
jeff kushner
North of Annapolis
http://www.expeditionforum.com/threads/hypertech-max-energy-2-0-first-impressions.33571/
I am using the Hypertech on my Expedition, and LMS on the Edge. LMS(Livernois) is definitely better but the Hypertech's 87 tune on the Expy is great for half the price of LMS. Plus the Hypertech could be moved to MANY other vehicles if the Expy is traded in.
Hey Loki,
You've helped out a lot of guys around here, especially in regards to the Sync systems and subsystems so I value your opinion more so than someone who was selling for themselves certainly but also as you've displayed that you're a knowledgeable, experienced guy with this tech.
So here's the question.....if money wasn't part of the equation, would you opt for the LMS or stay with the Hyper?
And here's why I ask. I suspect that the Hyper will do everything(& more) that I am likely to ever require. For me, I can plug & go...fine, I'm good with that. I don't need to reinvent the wheel to upgrade my truck, I just need to pay for it. So, is it as I guessed, that for most of us that really don't feel like laptop time, the Hyper is great.......but for those who feel the need to dive in and see how it all ticks, they should opt for the LMS?
Folks should know that for anything but P&P, you'll need to buy the interface as well.....Loki, please correct me if this is incorrect!!
jeff
07xln
Dallas
Hey Loki,
jeff
I know the question was directed for Loki but I felt I needed to chime in. Both the Hypertech and Livernois tuner are just flash tuners with “canned” tunes. I don’t think either one gives you the ability to adjust the tune as far as fuel and timing go. I think it’s just up to who you think has better tunes will determine which one you go with. I know you can adjust things like shift points, tire size, etc. with both tuners but I don’t think you can adjust things like fueling and timing. For that I think you would need something like HP Tuners where you can actually plug in and adjust the oem map
Moderator
Hey Loki,
jeff
Jeff, I appreciate the question.
I have had A LOT of experience with tuners over the years, most in the VW and Truck Diesel world. I have learned to tell the good from the bad.
Honestly LMS is top notch! I use them for my Edge, and they really aren't what I would call canned tunes. Anthony@LMS will tweak tunes, and you get 4 on the tuner at any point. You don't like the 4 you have, just put in a request, have him make some changes, and hook the tuner up to your laptop, and it pulls down the updated tunes. Plug it in to the car, and load the tune, and drive. There is ZERO you can change on the tuner as far as shift points...or anything else. They are on base tune revision 3, that was released a few weeks ago for the Edge. They have done regular work to keep improving the tunes. My current tunes for my Edge are:
93 v3 Performance
93 v3 Performance - Early Shift (WOT shift point is a couple hundred RPMS earlier, it has proven to result in a .2 faster 0-60 on the Edge)
93 v3 Performance - Early/Firm Shifts (Basically for me a 1/4 mile tune)
87 v3 Tow - Early Shift
Cost: $599
Hypertech is more of what I would call canned, but has more user adjustable settings. Total power I think even with 93 tune on both is less with Hypertech, because their tunes at all levels are rated for full Towing capacity. You can change the TCMS pressure setting, Tire size, adjust idle RPM, shift points per shift, and many other things. I run the 87 Tune, with all the Street options, and it is perfect for the wife's daily driver. I upped the TCMS setting so that I get a warning earlier for a low tire. I will adjust the Tire size when I do the lift. My cost was $260, but I caught an Amazon re-seller with a deal. They are being cost controlled now it appears at $349.
I think the better overall tune is LMS, but the Hypertech is GREAT bang for the buck, plus has a few easy user adjustable things that the LMS does not have.
Hope that helps.
-Ray
jeff kushner
North of Annapolis
Thanks Ray.....as you surmised, I was trying to frame the question to tee it up for your answer for you so it would read exactly as you have written it....THAT should be a "Tune sticky"
Reading it, it's easy to infer from your plain, easy to understand description of both......and from what I observed with your hyper charts....well worth a 300 buck outlay and includes a "safety" of sorts by being a bit lower in total HP....the owner should have no fear of lower end issues that they MIGHT in higher HP solutions.
Thanks Loki
jeff
07xln
Dallas
93 v3 Performance
Cost: $599
Hope that helps.
-Ray
Not trying to start an argument but if your tunes are being mailed to you, they’re “canned”. The tunes your running were developed from some test car of the same make and model, not your own. That’s why Livernoise offers tuning on their in house dyno for a true “custom” tune for your car.
Oldnerdguy
Bowling Green, Ky
With the LMS changes you request, do you have to download and send data in from your vehicle? If you are doing this, it would definitely be a little more than a canned tune. If not, is "canned tweak" a term? Haha (meant in jest not mean sarcasm)
Uprev programmers are the high end ones used for Nissan. The Tuners send you a baseline tune and then you go and drive the vehicle (certain exercises are needed along with some regular driving) and record data and send it back to the Tuner and they tweak according to your vehicle's data. And repeat this a few times til it is where you and they want it.
07xln
Dallas
You can’t log with the LMS tuner. Again you need HP tuners or EFI Live or the equivalent and a wide band o2 sensor.
Moderator
That is correct. No logging with LMS, or Hypertech. Limited with SCT, and HP Tuners. No EFI Live for most Fords.
Moderator
Yes, I do realize what Datalogging is, and what Custom Tuning is.
Here are my definitions of the different types of tuning and examples.
Canned - One or Very few vehicles were put on a Dyno and tuned, few people tested, then was released to the public - Hyper Tech, SCT(Non Custom Tuner Versions), SuperChips, BullyDog
Non-Canned(Tweak as OldNerdGuy put it) - Many vehicles were dynoed/tuned in person, continued development, and changes can be requested based on customer testing and feedback. No or Very Little Data Logging. - LMS, SCT(Custom Tunes via Computer/Remote)
Custom Tuning - Your Vehicle is on the Dyno, or extensive data Logging is possible. Also some can allow you as the owner to tweak the tune. - HP Tuners(Complete Control), LMS(In Person at LMS), SCT(In Person), EFI Live
Many above examples aren’t available for ours or many non-performance vehicles..[emoji12]
AllBoostNoEco
GA
Adding to the fun, I have an appointment in January when I get back from leave to get my truck on a dyno for 3 days.
Should answer some questions about what we really get. I’ve already confirmed they adhere to the SAE J1349 standard conditions (77 degrees, 29.92 barometric, etc), so it’s about as apples-to-apples as I can get with how Ford rates their engines. They are going to run it stock tune, then the 5 Star 93 tune to see how it performs, and then throw it in the trash and custom tune it from the ground up.
Moderator
Very cool! Who is doing it? Look forward to seeing the graphs!
AllBoostNoEco
GA
It’s a local place called Injected Performance. Seem to have their heads on straight and their lead programmer actually called me instead of making me call him when he wanted to get more info on what I was looking for.
Spoke volumes to me on their customer service considering I was only a prospective customer at the time.
Muddy Bean
Man all this tune talk is making me want more from my 3.5 TT. Ray, how much does the highest performance 93 octane tune affect daily driving manners? My truck is my family mover but we drive around 30,000 miles a year. Lots of hwy. I would love to push the max performance I safely can out of my 3.5TT. I don’t mind firmer shifting, but if it creates obnoxious daily driving manners (jerky shifts, touchy throttle etc) then I might reconsider.
Moderator
Honestly, I am not a fan of the Hypertech 93 Tuning. I have sent a few messages to one of their techs and they have adjusted, but still pulls to much power while shifting at WOT. The 87 Power bump with the Street Throttle and Shift Settings I have been very happy with. It allows me to get above stock 93 feeling while running 87. It is giving me the best of both worlds in my opinion.
This Motor pulls real good in low and the middle of the power band, but the Dyno graph Hypertech has published shows even more in the Middle and you can feel it. Been meaning to get numbers, but need get my GTech from my Dad.
No members online now.
Landsbutter
