Post a clear pic of the led on the pcb and we'll go from there.
I’ve desoldered stuff before. I actually enjoy soldering. Anyway, someone ambitious could swap out those LEDs for a color of your choice for you.
I have a color deficiency and green is one of those colors that I don't see very well. I can see the green grass and tree leaves and of course traffic lights but when you start getting into shades of green. I sometimes identify them as brown or even red.They are green for a reason. It has to do with vision and green is the color, eyes see best. Pontiac's however, had cool, red gauges. My 2011 Mustang, allows owner to pick color. I set mine on dark blue(night), white during the day.
I agree, too much work. Soldering on printed circuit board, is very tricky and not recommended. One screw up and you are buying a new cluster. Soldering electronic parts, can toast them, if they get too hot. A bad connection will cause intermittent, problems. The 1st gen, have odometers, with this problem(from the factory). You will be questioning your sanity, when you are pulling the dash apart for a second time.I don’t mind the green or white/blue, I wouldn’t spend the energy to change either or as they both work. The blue and white is a bit more modern but the green doesn’t bother me at all.
I worked for a company that built electronic PCBs they had a bunch of old women doing all of the soldering particularly for the small run boards. For larger runs and had flow solder ovens. But these women were very good and I learned a lot from watching them. One key tool was a big f~cking magnifying glass and a small tipped soldering iron. They also had special heat absorbing tape that they would put on the parts they were soldering. They would also wear grounding straps on their wrists.I agree, too much work. Soldering on printed circuit board, is very tricky and not recommended. One screw up and you are buying a new cluster. Soldering electronic parts, can toast them, if they get too hot. A bad connection will cause intermittent, problems. The 1st gen, have odometers, with this problem(from the factory). You will be questioning your sanity, when you are pulling the dash apart for a second time.
