Fuel Mileage in ye old toilet
sjwelds
Kansas
So the Fuel economy in my 08 EB 4x4 has recently took a major hit, like I'm talking over a mile per gallon less on the last couple of fill-ups. I know we have been doing more idling than normal, what with the recent cold snap and all, but still, this doesn't seem right...
Is winter fuel really that bad? Would it cause this?
What else could/should I look at? Fuel Filter? Do I have one external of the tank?
J Ski
3.5plati
VA
Check your MAF sensor. If it’s got buildup of gunk on it, it may throw off the MPG reading. I’m having a MPG issue with my 16 ecoboost and I’ve been advised to take them out and clean them. I recently installed a K&N intake system and my MPG have taken a 3-4 mpg hit
deweysmith
Montreal, QC
It’s not just winter gas, colder air is much more dense, which means there’s more of it to move out of the way. On small cars this isn’t a huge deal but on an Expedition with its big front profile it makes a huge difference.
S
sjwelds
Kansas
Yeah I know on the fuel. Was just not thinking it would make that much difference...
Good point about the denser air...
ExpeditionAndy
Fort Wayne, Indiana
It is pretty common and I experienced that on my 05 and on my 17. It's nothing to worry about, it will get better in the spring.
S
sjwelds
Kansas
Thanks.
Just installed an AEM dryflow performance air filter and sprayed out my maf sensor with CRC mass airflow sensor cleaner. Guess we'll see if mileage ticks back up.
ExplorerTom
1 whole mpg?
I've tracked every fill up in the 44k miles I've owned mine and I see variations of more than 1 mpg from tank to tank all year round.
Personally, I'd say 1 mpg is within the noise.
J Ski
3.5plati
VA
1 whole mpg?
What would you expect the culprit to be for my 3-4mpg loss after intake installed?
1997SCEBFEX
Northwest Panhandle
aside from weather, there might be something else as the culprit.
MAF
Fuel filter/air cleaner; former on frame rail (I believe & for my model anyway.)
intake sludge build up
injectors
sure others will chime in.
Have you done any other maintenance?
Still guarantee it’s weather mine is averaging 14 MPG in this cold and normally averages 17 MPG, it starts climbing back up as soon as we get a warm day.
ExplorerTom
A K&N intake? Assuming based on your signature.
2 things come to mind:
1. You drive it harder because the intake sounds cool
2. The filter is oiled too much and that oil is now covering your MAF downstream.
J Ski
3.5plati
VA
MAF
injectors
Truck has 20K miles on it and gets oil
Changed every 3500 miles. If any of this stuff listed is the culprit Ford is going to have some explaining to do. I don’t have a MAF, they are now MAP sensors (3 I believe) which I may end up cleaning with some CRC
J Ski
3.5plati
VA
It’s oiled from the factory and you can barely tell it’s even got oil on it
plumcolr
freehold nj
Check for a dragging brake caliper. Easiest way is with a cheap gun type remote thermometer; drive ten or more miles and immediately check the front rotors and the rear rotors. If there is a difference left-to-right (forget front-to-back) the hotter rotor is dragging. I'd say check with finger but if it is really dragging you could easily end up with a blister.
plumcolr
freehold nj
And it's not winter fuel so much as even injected it's run slightly richer until the engine is at operating temp. Cold start also means fluids (oil, trans fluid, gear oil) are thicker, so the same engine performance requires more fuel.
You have a MAF sensor, every modern engine does. That is the mass airflow Sensor that measures air being taken into the intake into the engine for combustion. The MAP (Manifold Absolute Pressure) sensor measures vacuum not incoming air.
rjdelp7
2000 XLT
NY
In western NY it has not been warmer than 19, in two weeks. It is near 0 at night. Mine is down at least 2+ miles per gallon. I do not do any extended warming up or idling and mostly short trips. The extreme cold, kills gas mileage.
J Ski
3.5plati
VA
You are incorrect. Ecoboost 3.5s DO NOT have MAFs, they are MAPs and there are three of them. Our motors are speed density based and do not use a MAF sensor. Airflow is calculated based off intake manifold pressures along with temps.
