Shifter Cover
AllBoostNoEco
GA
I have some refining to do, as you can clearly see from the excess of material, but I have a start to making the shifter look a little nicer than the factory plastic box that sits there.
I made some measurements and some uneducated guesses for the material, which proved a little bit off on the guesses, and this is what I came up with. I have a ton of leather left to work with, and it only cost $7 for a square yard or so.
ExpeditionAndy
Fort Wayne, Indiana
There are some companies out there that will make a leather boot for the shifter. I do like the way that looks.
Was the center part of your shifter black or did you paint it?
AllBoostNoEco
AllBoostNoEco
GA
I had the leather lying around, so I decided to run with it. I already cut and stitched a new one with about half the material, I’ll be trying it tomorrow. Due to a lack of attaching methods, I ended up using self-drilling screws to attach it.
My shifter came black. It’s only an XLT, so no fancy chrome for me.
ExpeditionAndy
Fort Wayne, Indiana
Did you wrap it around the plate that was there or screw it in from the bottom?
I hate the chrome. If the sun hits it at the right angle it shines right in my eyes.
AllBoostNoEco
AllBoostNoEco
GA
I’ll have to take better pics tomorrow, but the part of the shifter that has the gear indicators on it (P,R,N,D) is what I screwed it to. I left about an inch of material below the top of it. I wanted to attach it to the shifter surround, but there was no way to keep it from pulling up through the hole. So I settled since you can’t see it anyway.
My wife has the chrome in her Plat, and I also find it annoying for that same reason.
AllBoostNoEco
AllBoostNoEco
GA
What I attached the boot to.67B6AD19-5C91-4C98-BD8F-B48295582D89.jpeg 39BE9292-87B2-495C-8E4F-566951CC8D6F.jpeg 4FA95024-64F5-4B09-87D8-297232A8BA6D.jpeg
Revised product. I did discover that you want to use something other than the 1/4” screws I used. The heads are large and the console top won’t fit over them. I moved the one in the back down, and just whacked some of the plastic off to make it fit.
Given that, I’m still happy. A small, easy change with a big impact since the redundant gear indicator is gone.
deweysmith
Montreal, QC
Yep, typically that’s what it is. You pop the plug out and insert the key or a screwdriver or something and it will allow you to shift from park with no power.
GeezingInVA
Clifton, VA USA
Same here. That's why I carry an old black sock inside the console that I slip over the shifter when the glare is too bright. :driver: I do my best to try to ignore the fact I have an expensive Exp that I have to junk up with an old sock just to be able to enjoy driving it. :chair:
ExpeditionAndy
Fort Wayne, Indiana
I hear your brother. I'm thinking about getting a scrap piece of black vinyl and just cover the top of the chrome down to the bottom of the leather grip. I think that will make it look nice and I'll still keep the chrome on the bottom of the shifter.
AllBoostNoEco
AllBoostNoEco
GA
FWIW, the actual black shifter is only $18.27 plus shipping. Two T20 torx screws to swap it out.
