PCV hose part #
Ps4acc88
Dallas, TX
Hello all,
I'm in the process of getting the expo ready for a spring break road trip. I plan on having the plugs changed, transmission fluid flushed, and replacing the pcv valve hose(along with oil change and the other normal things). I'm having a hard time finding some where to buy the pcv valve, I get no direct results online and I don't want to risk ordering the wrong part. A site i can order it from or part # would help.
Also, would it be recommended to change coil packs? Or just replace them as they go out?
2007 expedition with 137k miles EB 4x4
Daily driven and never really tow anything
Any other suggestions are welcome thanks.
AllBoostNoEco
GA
This is what I found through Rockauto. Apparently the PCV valve is part of the hose. No listing through Ford besides that same connector hose.
AllBoostNoEco
GA
Yeah I saw this but was skeptical because their part # brought up no other results. But it looks like I may have to take a chance.
It’s the same part number I got on Tasca Parts, who is my usual go-to for OEM Ford Parts. Maybe someone with more experience with the 5.4 will jump in. My only 5.4 I traded in with 145K on it and I never changed the PCV.
Ps4acc88
Ps4acc88
Dallas, TX
Another question, this part here I also need to replace. Also having a hard time finding it, s searching anything intake related but not coming up
AllBoostNoEco
GA
I can’t find anything. Is there a part number on that white sticker by chance? Or one molded into it?
Skip the coil packs, only replace *if* they ever go. I’d advise against a flush and advocate for a pan drop and filter swap/refill instead, Flushes can cause some issues. The RockAuto PCV will work I’d get the motorcraft one, they let you do returns anyway so you wouldn’t be taking a chance and they ship ultra quick. Generally the stuff will be on your doorstep 1-2 days after you order they are that quick.
