Vancouver Bob
[emoji849][emoji849] 3 more wheels till they’re here
What happened to the wheels you had? Are you out doing us and jumping up to 37's?
Yeah got new wheels and waiting for them to release, why it’s taking 3 weeks, and then the 37s will be on !What happened to the wheels you had? Are you out doing us and jumping up to 37's?
Bead Lock's ??Yeah got new wheels and waiting for them to release, why it’s taking 3 weeks, and then the 37s will be on !
No changed my mind last second just went with aluminum wheels but they haven’t come out yet... little did I know, and I already paidBead Lock's ??
Man Bod , we need to step up our game. HahahWhat happened to the wheels you had? Are you out doing us and jumping up to 37's?
Lol thinking gonna try my best and do the 6” F150 lift too but that won’t be for a whileMan Bod , we need to step up our game. Hahah
Did u go with a bigger offset than the -6No changed my mind last second just went with aluminum wheels but they haven’t come out yet... little did I know, and I already paid
Yeah, 17x9 -12 offset that’s the main reason I went with this wheel hard to find that sizingDid u go with a bigger offset than the -6
Yeah the only thing that's holding me back on that is the rear.. I ant into that squat look.Lol thinking gonna try my best and do the 6” F150 lift too but that won’t be for a while
What I’m planning is to do the 6” lift from BDS or Zone and run coilovers at 4.5”-5” that way with the bumper it should sit right about where it is now with the 3.5” lift, and then leave the back how it is. Talked to a BDS rep and he thinks everything should work out with running the coilovers at 5” and using a 6” spindle. So hopefully I’ll get the kit on and then get it to squat down a bit, and it should be a bit like long travel as long as I keep the sway bar off.Yeah the only thing that's holding me back on that is the rear.. I ant into that squat look.
And if u don't do something in the rear then that's what's gonna happen..
I been thinking really hard on this for the past year trying to come up with a way to do a suspension lift . The rear is the only real problem . U could easily drop the upper control arms and drop the lower control arms say 2" and add a taller strut spacer to get the 6" lift .
This is the idea I been pondering on bc without the extended spindle u would have to drop both uppers and lower control arms to keep the ball joint geometry the same. No binding..
