Afair, there was a FACTORY dual battery option.. either in some of the 5.4 years on expy, or maybe I'm confused and just on 5.4 F150s...
I meant a kit for adding that same setup later
A portable jump box is the easiest way to go.
Big enough for 5.4L triton? The "1000" model is on backorder
Needed a jump AGAIN, barely an hour after starting just fine to move to a better parking spot.
Can't tell if it's me overusing the power sockets for charging phones and tablets and shit, or if it's multiple lock-unlock cycles & the HIDs with the way it lights all the lights when you hit the remote
How far do you drive in a normal day? My commute is 2.5 miles one way, and if I don't put hook up a charger or drive a decent distance (allowing time to recharge the battery) my battery will die in less than a week. I usually discover this on Monday mornings if I don't go somewhere on the weekend.
Ford leaves the 12vDC accessory outlets hot at all times so anything plunged into them like your GPS and radar detector will siphon the battery dry after a while parked. A long weekend would kill my '07 Expedition battery and parking at the airport required a battery disconnect under the hood. I'm being very careful with the '17 truck.
Starting batteries are severely damaged by deep discharges and you only get a handful before the battery is toast. Deep cycle batteries are designed for this abuse and some "marine" batteries claim to handle both.
I "fixed" my Valentine-1 radar unit by an accessory in the OBD2 port that powers the unit and cuts it off with the engine but the GPS is still running connected to the "cigarette lighter" socket.
Is there a way to cut the voltage to the accessory sockets? Forscan?
-- Chuck
