Habbibie
Is it Christmas yet?
Chicago
Gain can u please take a couple more pics close up of the new brackets and the double pulley set up I been wanting to run two alts on my expy for the high amerage inverter I have to use and it's draining the he'l out of my batteries like there's no tomorrow
GaryH2
SE PA
Changed the sunroof weatherstripping yesterday. It had a cut in it and was getting pretty stiff after 10+ years exposed to UV. Also ran it through a car wash to get the salt off before our next storm (which is why I changed out the weatherstripping! o_O).
J Ski
3.5plati
VA
got 2 370 alts fabbed up on the truck...air intake isn't what i pictured would be made for the truck but for now it seems to work... Will have to go to a shop to have the air flow rate figured out compared to what it needs to be
The 370 alt on the motor is putting me at 15.2v which it is handling well... only aggravating thing is the alt regulator is wired to bypass the pcm and is causing my charging light to stay on throwing a code... the fix is to send the alt back for them to rewire the regulator and add the middle pin and wire for the pcm to recognize the alt is there to stop throwing the code... but I can't do that for a while
Motor alt has a double pulley which the fan shop welded together... if anything happens to the other alts I'll be able to disconnect without having to be without the truck cuz it's own belt systemf24a7985982b5da239492eea7a1f973f.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
Dude that intake isn’t doing jack shit with all those bends in it. Please tell me that’s painted black PVC tubing. Your performance is going to suffer considerably
Boose
2017 Platinum EL
NJ
Did you tint yourself? Or are those replacement tail lights?
Dorzak
Back at the dealer. Roadside assistance brought me here for tire patch. Went into store and came out to a flat. Sheet metal screw with a washer on it.
Habbibie
Chicago
And you couldn't plug it, used run flat sealant, refilled it with air or put the spare tire on? Kinda seems like you like being at the dealer... gotta keep those hands silky smooth
Newport News, VA
Yeah I'll take then tomorrow for u
Newport News, VA
Temp setup
Dorzak
I went there not because I couldn’t do it myself but because I am under warranty including roadside. Why not let them do it while it was covered already?
Plati
Especially as I get older, like to use a mix of services and my own labor. If I can and want to do it myself - great. Times it makes sense to have someone do the work.
Dorzak
It isn’t just getting older for me. There is more in my mental calculus
1 - It is covered. Doing it myself saves me nothing and costs me materials.
2 - I am dressed for office work not auto work. I have calluses from working in a lumber mill and construction for years. I also wore different clothing I didn’t mind getting tire marks on and didn’t care if it didn’t wash out.
3 - parking lot is sloped. I don’t like trusting the emergency jacks if I can avoid it, especially on any slope. Roadside brought chocks and a floor jack.
4 - I would need to walk to a parts store for patch material. Fix a flat goo is a pain to clean up afterwards.
5 - I still get pains in neck and back if I exert myself. I don’t like my neck imitating breakfast cereal - snap, crackle and pop.
Plati
My neighbor had a screw in a tire making it flat overnight. They ended up having to replace all 4. Shop said where the screw was they couldn't reliably fix with a plug & the tires were worn enough that putting a new one on would create a problem.
The days when I actually want to change a tire or fix a flat with a plug are behind me. Kinda like my roof. I put a complete roof on my house in 1989. Now days, I do not believe I can hoist a pack of shingles up a ladder over and over again. Glad to pay somebody to do that.
Adieu
SoCal
Found some nasty rims (fixed with bedliner) with Prated tires for $50 on Craigslist
Its a surprisingly exhausting project, but daaaaaamn does it ride smooth vs. LTrated BFGs.
ManUpOrShutUp
Ordered front/rear pads (Akebono ASP) and front rotors (Raybestos Police). $252 OTD. Only the fronts need to be done, but Pep Boys has the pads at 25% off so I'll toss them in the garage until they're needed.
Got my shovel mounted, cleaned the truck and took some pics. That’s all.
Just out of curiosity, do those PIAAs actually put out sufficient light to warrant their cost these days? I had a set way back in the late 90s and they were awesome, but reviews on the modern iterations are pretty lackluster. The stocks are ok, but I do a lot of driving on NPS roads and could really use something better.
Adieu
SoCal
Installed yet another fits-F150-only product (real caps not stickon covers...direct fit, though, so stands to reason the stickons would all also work):
...jacked up a mirror glass on one side doing it, though.
Oh well, in two days we'll see if F150 glass fits
