Rear Diff fluid change questions
Vankonk
WI
New to the forum and new to my used 2016 Expy EL Limited. Bought it used with 60,000 miles in Dec 2017. About a month ago I noticed a hum in the rear end at low speed turns. It has steadily grown over the past month into a vibration that can than be felt and heard. Before I bring it in, I thought I would change out the read diff fluid since I have done some research on the forums.
I crawled underneath and found the info on the rear diff is 3L73 - 9.75. I see the drain plug and fill plug. I purchased the recommended Motorcraft gear oil and 4oz of friction modifier. My question - is this a quick dump and fill? It seems easy enough but thought I would ask for any experience or pointers before I mess something up. Thanks.
Black
Kentucky
Yes it is a quick dump and fill. Well not exactly quick since gear oil is quite thick, Though I would use Amsoil instead of Motorcraft. I have found it to be superior. It is all I use in transmission, differentials, and transfer cases anymore. Motor oil I have not noticed a difference but I also refuse to go past 5k for any oil change so good old Motorcraft is all I really need.
I do differentials and transfer cases at 50k because gear oil is cheap.
Transmissions at 75k.
Are you running auto 4x4????
My old Explorer would do this when tread depths were substantially different for the front and rear. Even with fresh fluid. New tires solved the issue.
V
Vankonk
WI
It stays in 2H all the time unless I need 4auto for snow.
I did drain it last night and I think the previous owner or dealership either used the wrong fluid or it was severely broken down. It ran out like water. I was expecting it to pour out but not like that. It was empty in a matter of seconds. It was dark and there was no signs of water contamination, just very runny. Also when I pulled the fill plug up top, fluid started to leak out of the fill. One other observation, was both the fill plug and drain plug had some type of grease covering the magnets. Not sure if that was normal or not. So a couple of strange things.
Changing the fluid fixed the problem. No more shutter/vibrations in slow turns. I ended up using Mobil1 75W90 full syn with the friction modifier. I know that's not the recommended oil so I might get some amsoil and do it again. Like you said it doesn't take long and not that expensive. I didn't even need to jack up the truck to do it.
Black
Kentucky
Glad fluid fixed the issue.
Sounds like they did not add friction modifier either.
I just hit 47k so I’ll be doing my differentials and transfer case at the end of the summer.
Which will be good just in time for winter when my 4wd gets used most.
07xln
Dallas
My 17 model with 16k miles on it does it only when it’s cold. My 2012 ctsv does it only when it’s cold. It’s just a part of having an LSD rear. With that said that doesn’t mean all of them do it. The clutches are grabby when the fluid is cold and that’s why the hum around slow turns. After a mile or two of driving it shouldn’t do it anymore because the fluid heats up. A fluid change will remedy it but chances are the noise will return especially when it’s cold out. Nothing to worry about
Black
Kentucky
Never had this issue with any of mine. A properly working and lubricated LSD should not chatter.
07xln
Dallas
It’s not chatter. Like I said, not all of them do it :waytogo:
1955moose
I'm a little confused. In your first post you stated you purchased the correct motorcraft oil, and 4 oz of additive. Then you stated you put in Mobil 1 75-90 oil that you'll be changing! Why didn't you use the Ford oil you bought at dealer?
UncleDJ
Central OH
With 68k on my 14 EL, I can't say that it's ever been changed so I'll gi-er-dun. I'll go full synthetic and go with friction modifier, but don't know what weight and how much.
Any suggestions appreciated.
Thanks a bunch. :)
V
Vankonk
WI
1955moose.....good catch! I screwed up and never looked at how much oil I needed. I only bought 1 quart of motorcraft and needed two. Didn’t realize I was screwed until I drained the diff and saw how much came out. It was late and only thing open was advanced auto so went there and bought what they had.
16plati
VA
Will be performing rear diff fluid change on my 16 to fix the same issue, vibration and rumbling at low speeds after turning left or right from a stop
16plati
VA
Did you use the owners manual recommended SAE 75W85? I see OP used 75w90.... what should be used?
16plati
VA
Tht “grease “ is apparently minute pieces of metal. Normal for wear in period. You do not want to see chunks of metal in it
Black
Kentucky
I used Amsoil 75-90 Severe Gear Oil I do not believe Amsoil makes a 75-85.
I used Ford Motorcraft Friction Modifier.
I believe Amsoil is call Sliploc I have never used it as strangely no one carries it locally.
16plati
VA
Awesome, did you just pull the drain plug or use fluid extractor? I’m trying to keep this as cheap as possible so pulling plug and letting it drain seems to be easy enough
