What does sport mode do?
frontman94
wv
I looked and couldn't anything on this topic so if i missed something i apologize. What does switching from normal drive mode to sport mode actually do. Can you tell a difference when switching between the various drive modes?
Aquineas
If you have the 4WD model it will also switch the car into 4A mode (for traction). I switch to sport mode in the rain for this reason.
aggiegrad05
North Texas
Not me. Harsh shifting is very noticeable.
This. I can’t drive in Sport. Waaay too jerky on the upshifts and the car shudders when coasting to a stop because you feel every. single. downshift. And I know it’s not but the engine always sounds like it’s about to explode because it holds the shifts so long. I didn’t buy the platinum to have it sound like it’s working itself to death.
Blackscreen67
Born to spool
TEXAS
Believe it or not, but those firm shifts are actually a good thing. It means the line pressures are elevated and not delaying clutch engagement. The major benefit to this is better clutch holding ability, less clutch stress, less chance of slipping the trans(some trans have designed slipping which is stupid).
Long story short the 10R80 needs all the help it can get, and if you want that adaptive POS software to not wreck your trans prematurely always keep it in sport mode.
With the revs, they're designed to shift at "optimal" point in the power band.
I was averaging around 15mpg always running 4wd sport.
Garrett
Kansas City
That’s fine and all, but I’d rather feel like I’m riding on a cloud.
Blackscreen67
Born to spool
TEXAS
Lol, I can understand that! That clouds no good when it's posted up on a rack in the service dept. Some 10R80 replacements are just being rebuilt instead of replaced which is crazy being many of the techs at these dealerships barely have the qualification to do a teardown let alone a rebuild.
Usually a good ole 4-6wk turn around time lol.
aggiegrad05
North Texas
If it breaks it breaks, that’s what warranties are for.
I bought this to be comfortable. I’m not going to drive uncomfortably to maybe one day avoid the shop. I’d much rather drive the way I want to (on a cloud of CCD bliss not feeling any shifts) and then happily take the free loaner for a month 4 years from now in the unlikely case that my transmission craps the bed.
And I certainly don’t care about gas mileage as I drive the automotive equivalent of the USS Saratoga.
Blackscreen67
Born to spool
TEXAS
That's respectable! Just be one with your car and all' well that ends well.
proeasy
Michgan
Why so negative on adaptive shifting, has been around for decades, and as you note even takes into clutch wear and will adapt shift times over the life of the transmission to maintain shift quality and as you note reduce clutch wear.
AT's need slip you can not just instantly fully engage a clutch or brake, in a lock up Torque Conveter for example to mitigate driveline vibration. Modern AT's are amazing in terms of efficiency and the down speeding allowed with Lock up TC's and modern dampers in them. Slip is a much overused term in AT's the "Slip" takes place in milliseconds
Artie
Georgia
Seriously. When my wife makes any remarks to my mileage I remind her that A) she drives a Honda Fit and B)I drive a 6000lb 450 hp tank....
that being said, we may flirt with a hybrid if one comes out but knowing how my right foot is prone to abuse the accelerator I doubt it would make much of an improvement.
