Grill and Foglight removal??
Black
Kentucky
Any tips on grill and foglight removal on a 2016. Any hidden clips or sweet spots to help remove them?
Going to be doing away with the chrome.
Thanks
Munkiebunz3
Soviet Monica, Kommiefornia
I've only removed the fog lights after having removed the bumper. They're just screwed on. The grille is screw clipped on to the top trim and to the bumper for sure but I can't remember if it's attached on the sides. To verify, It's really easy to remove the headlights (two bolts on top & pull straight forward after releasing the top clip) . Doing so will give your hands some generous room & help you see behind the grille.
Black
Black
Kentucky
Black ,did you find a compatible grille replacement? I too want to eliminate the chrome.
No replacement.
Tested Rustoleum Peel Coat (failed)
Now going to test Gunmetal Plastidip with Glossifier. I don't just want flat black. I want it to contrast slightly with the already metallic like graphite color that is two toned with the chrome.
I know some folks that have a laser duplicator and a 3d printer but I am not sure the grille will fit in the duplicator. But I need to get a chance to run it over there.
If that fails, I will have it professionally painted as even junkyard grilles are $750 and I don't want to screw it up too bad. The Autobody I use has a lifetime guarantee.
star-art
Pacific Northwest
The grille is chrome-plated plastic. This is done with a process that deposits a coat of copper on the part and then overlays nickle and chrome over that, so it is a real metal finish. I imagine if you scuffed it and used a quality metal etching primer you could successfully paint it. But, of course, anytime something impacted the grille (bugs, etc.) the paint could be chipped off. I wonder if some sort of powder-coat finish might be a better choice (but I'm not sure that's possible with plastic?).
I still don’t understand why the grille is so expensive. The grilles are just plastic sprayed with a chrome paint, nothing special. I don’t believe there is any “real metal” finish to them at all, when they age they bubble up. The 07-14 one is about $300 which is expensive enough, then $650 for the 15-17’......crazy for a stupid piece of plastic.
Black
Black
Kentucky
There are low temperature powder coats (for plastic) but they tend to be a flat or matte finish which I do not want.
Hydrodipping is another possibility.
Trainmaster
Old School Member
Rockaway Beach, NY
The SSV (police fleet) grilles for the 2007-2014 are a low-luster black as is the 15-17. You can clear-coat one of these for a gloss. This guy wants $270 for a used, unplated piece of plastic:
https://www.ebay.com/itm/07-08-09-1...311346?hash=item2ab4e19df2:g:vMEAAOSwiZZbjlrW
There is also a black chrome grille that was used on some year black Limiteds. Some other year black Limiteds had a high gloss (painted) grille. Look on ebay.
Black
Black
Kentucky
I would just buy the factory one in the black/graphite color.
But I have yet to locate a 15-17 grille for under $750.
AllBoostNoEco
GA
i know you said it didn’t work for you, but this was how mine came out using Peel Coat in graphite. I did the front and the trim on the back last September. The back looks like the day I did it, the front has a few chunks missing now that it’s been 13 months.
7CC95FD7-2817-4829-B114-B683840EFEC4.jpeg 680B05E7-BD13-4793-85B1-0408F70A9A4E.jpeg
Black
Black
Kentucky
That is exactly what I am going for!
I must have had a bad can.
I have one more. I guess I’ll test it on something else.
AllBoostNoEco
GA
It’s been a while, but if I’m recalling correctly, I cleaned the grille by taking it off, rinsing it, then scuffed the chrome with a green Scotch Brite pad and tossed it in the dishwasher with soap to get any wax or grease residue that might be on it off.
Then I sprayed it normally, going extra-light on the first few coats.
Nellynel
Chicago
I removed my grill and fog light trim to vinyl wrap here a pic from behind the bumper.Screenshot_20181004-204216_Gallery.jpg
Black
Black
Kentucky
I am needing a Chrome grill. Is yours available ?
If you have a blacked out version to trade.
I am going to refinish my factory grille unless someone has one to trade.
