Never as easy as it should be.. Front suspension
Bain64
No help needed (yet), I just wanted to share. I've been getting a little clankity clank going on in the front, and I knew the driver's lower ball joint was well past it's prime so I decided to change it out. I found the upper control arm ball joint was looser than this gal I knew a lifetime ago, the strut is rusted through, and two of the brake dust-shield bolts snapped off inside the knuckle... I'm waiting on the 2nd vehicle to come back home so I can go get an extractor kit and get it put back together.
Anyways, at least I've got some great help!
justKen
Colorado Springs, Colorado
Two (2) jacks - one with a 4x4 between it's saddle and the truck - and your child lying beside the truck.
Please tell me the jack stands are present, but not visible in these photos...
/K
1955moose
Good looking boy! Good to get him interested in cars/trucks early on. I had to learn on my own unfortunately, would have been great working on the 53 Pontiac wagon, or my Dad's 57 Dodge pickup.
Bain64
Bain64
/K
Good looking out!
Yes, 2 jack stands in place and supporting the load, plus the main jack and then the small one with the 4x4 I used to position the control arm up enough to get the ball joint press on.
Edit: And i should note at no point was the boy under the truck, even with jackstands in place.
Bain64
Bain64
Thanks Moose. It’s in this little guys blood! If I’m working on something he wants to be right there with a wrench in his hand too. If we see construction equipment or anything of the sort he’s asking questions.
justKen
Good looking out!
Right on / I know how easy it is to get sidetracked into a project that "will only take a minute" - then these projects tend to grown exponentially and the most basic of safety measures have gotten overlooked.
Kudos for teaching your son working on your own vehicle can be both enjoyable, as well as rewarding in a completed job!
/K
Bain64
Bain64
Well, she's back on the road. Ended up with a new caliper too
How long do you think this strut will hold up?
Hamfisted
Ft Lauderdale
That strut is trashed .... the anti-rattle spring on the caliper is installed incorrectly. If they were both like that it creates interference between the rim and caliper, and the spring being the weak link will get knocked off by the rim. You must've been hearing that noise for a while ? Are you the original owner ? You can freeze frame this video to get a look at how the anti-rattle springs are supposed to be installed. Also, stick-on wheel balancing weights generally don't work well with Expy rims. There's very little clearance between the brake caliper and the rim. I would recommend using the standard smash-on weights, not the stick-on type.
Gary Waugh
Princeton, TX
how has the wheel managed to hit the caliper? was it not mounted correctly? or have the wheel bearings started to fail and allow the wheel to move enough to hit the caliper?
Bain64
Bain64
The big clip was missing that pulls the caliper down towards the wheel hub, instead it was free to flop out onto the wheel. I assume whoever changed the brakes last set the clip wrong on both sides. See my first two pictures from post #7. When i replaced the lower ball joint last weekend I noticed the brake clip was gone so I replicated how the clip was installed on the passenger side, which ultimately turned out to be a mistake. If you look at the clip on the second picture on post #7, you can see the clip installed touching the brake pad slides, when it should've been more outward. I ended up buying a new caliper because it was still so sloppy with the incorrectly installed clip. I then looked at it again and realized where the clip should be instead and fixed both sides.
