Torque Converter Shudder at 35-45mph
an7mal
Dayton
My 2007 Expedition EL got the dreaded torque converter shudder at 140k miles. Happens under light load in 4th gear (typically ~35-45mph) and varies from slight shudder to awful shaking. If you turn off OD it disables the torque converter clutch (TCC) and helps avoid the shudder. Or you can manually put it in 3rd gear and accelerate through 45mph. If you don't want to mess with the shifter, a deft touch on the gas pedal can be used to accelerate through the range (kicking it down to 3rd and then timing throttle lift off to shift into 5th) or you can avoid light load situations that require 4th gear (try to keep it in 5th, coast if it's in 4th).
A buddy of mine works for Ford and told us to get rid of it before it hits 150k miles. The F150 forums talk about the SHUDDER as well. It's important to make sure you don't have a spark plug or coil-on-plug issue as they have similar symptoms.
'Fix' options:
- Transmission/torque converter replacement (ranging from $400 ebay, $2k from Rockauto rebuilt, to $3-5k from various tranny service/dealers).
- Fluid/filter change.
- Friction additive.
My tranny fluid went from looking new and red at 130k miles to looking kinda nasty after my wife got fed up with the shudder, so I opted to order 8 quarts Mercon SP (for 07-08) and a filter from Rockauto.
FordTechMakuloco on youtube has some helpful videos. He suggests avoiding the purge treatments since a thermostat will keep them from actually purging most of the fluid anyway.
You can do this without jacking up the car (a tight squeeze and I usually bonk my head some), but it's easier if you level the truck on jackstands or use a lift.
1) remove filler plug with 19mm (do this to break the vacuum holding the pan on).
2) remove dipstick straight up to avoid breaking (or see below for my fix).
2b option) stick a fluid transfer pump hose in the fill hole and pump out as much fluid as you can - I got about 5-1/2 quarts from the pump and only had to dump 1-1/2 quarts from the pan.
3) remove 21 8mm pan bolts starting at the rear (you will probably need a wobble or u-joint to get the ones above the exhaust) and leaving the front for last (so you can hopefully catch most of the fluid when the rear edge drops first).
4) drop old filter (sometimes it falls out), make sure rectangular o-ring isn't stuck in the hole.
5) keep reservoir under tranny as it will keep dripping.
6) clean up pan/gasket surfaces - don't use the cheap gasket that comes with the filter kits as the stock one is higher quality and reusable.
7) replace filter (make sure your replacement looks the same as Ford switched styles in December 2007), make sure the o-ring seats firmly in the correct hole - it will be dangling unsupported so you want to do the next step quickly before the filter falls.
8) stick gasket/pan back up.
9) put a few front bolts in loosely to hold the pan up and keep the filter from falling, then get the rear ones started as they are the hardest.
10) don't tighten the bolts until you have them all started, then snug them all up.
11) Use a transfer pump to pump in fresh fluid (hook hose through transmission cooler line bracket just forward of the fill hole), I put in about 5 quarts before it started overflowing.
12) You can start/stop the truck briefly and add in about 1-1/2 more quarts but after that mine overflows unless the truck is running.
13) With the truck running in park, add fluid until the level is correct on the dipstick (I shot for low as I don't like working around that hot catalytic converter - wear a leather glove and long sleeves). I put mine about a 1-1/4" or 30mm from the bottom of the dipstick 'cold' but running in park. Put the cap back on with the truck running or it might overflow like mine does. When refilling, note how much fluid you drained. I pulled out ~7.5 quarts and put about 8 back in.
I recommend using a fluid transfer pump to suck out most of the fluid from the pan before you drop it.
If you have a 2007 Expedition built before December, it may have a shallow transmission pan, in which case the Filter that everybody insists is correct won't fit. A helpful guy at Oreilly did a reverse look up for me and then sent me on a quest for an in-stock 2007 Ford Explorer 4.6L transmission filter before it started raining. Autozone had it for $12.99. The later pans have an obvious center sump sticking down low and the filter is much larger and square-er (left filter in pic).
My dipstick snapped off and apparently isn't made of ABS as ABS plastic solvent didn't stick it back together (black glue in pic). I cut off the remaining stub of the broken dipstick, drilled/tapped the handle for a 10-24 bolt, glued it in with 5-min epoxy (you can speed it up drying with a heat gun), then cut the bolt off at 47mm like the stock dipstick. Permanent marker a few 1/2" or 10mm increments and aim to fill ~3/4" or 20" from the top.
The fresh fluid seems to have solved my shudder issues and you can always try the anti-shudder additive tricks later.
Fluid transfer pump, 'later' filter on left is bigger, squarer and bottom has huge pickup which sticks out in the a bulging sump in the bottom of the pan. Pre December 2007 filter on right is for flat pan (used in 2006-2011 Expeditions supposedly). Diptsick.jpg
Broken stock dipstick left (black is failed ABS solvent repair) and drilled/tapped screw epoxied in handle and cutoff to 1-7/8" 47mm.
Motorcity muscle
Motorcity
Voted in the above poll that I lived with it, but did change the fluid, but seems to be acting up more now that it is colder out. Just under 120,000 miles on '07.
dmm5157
I voted shudder fix & tranny fluid swap. I used the shudder fix additive to test if that was indeed the problem. Added the $5 bottle of solution and sure enough, shudder disappeared instantly.
After that, decided to swap out the tranny fluid for more permanent fix. That was 2 years and 45,000 miles ago, still going strong. I'll be crossing over 200,000 miles on it soon, truck had the shudder when I bought it 3 years ago and it had 145,000 miles on it. So glad the fix, in my case, was simple.
Clever fix for the broken dipstick, mine broke as well.
I haven't taken the time to buy a replacement, but I may since I see an OEM one above.
1955moose
Did the $5.00 shudder fix come as part of the filter and gasket? Or do you buy it separate? What brand is it?
dmm5157
Lube Gard Instant Shudder Fix is $7-9, then use a 20% off coupon to drop price down at Advance Auto.
All I did as a test was to add some to my transmission (Was only able to pour in about 1/2 a bottle. Took for a test drive, it "fixed" problem instantly. At that point, I realized the fluid may be the issue, so I went ahead and swapped out the fluid as a more permanent fix.
It's not a fool-proof approach, but it worked in my case.
https://shop.advanceautoparts.com/p...-522SruGlXQBV-SRgWsaAlo_EALw_wcB&gclsrc=aw.ds
dmm5157
Also, FWIW, I dropped the pan for my tranny and it was a nightmare. My truck must have been modified, because it took gymnastics to get it to clear some hoses that didn't show up in the videos I watched on Youtube. Also the tranny filter I bought did not fit, so I only swapped out the fluid and not the filter.
I won't drop the pan again, too much headache for my particular truck.
1955moose
Thanks for the info on the shudder fluid. The screens/filters stay pretty clean. On mine with 30k changes, I change filter every other time. You can actually spray with brake clean or brush with cleaning solvent and reuse. It always amazes me as big as these SUVs are, how parts are crammed in every spot. When I do a new job, and it's easy, I'm suspicious.
I won’t drop my pan again, was kind of a pain toward the back where the exhaust comes together right under it. I ended up stripping 2 of the original bolts threads (long story). Replaced with new bolts/washers and thread locker all sealed up well. Both still grabbed some torque with the new bolts. I used Mercon SP along with a new filter and added some Lucas trans fluid conditioner. Shifting and overall operation has been good and an overall improvement from previous to the service.
PaulT
new york
I voted for the plug fix. Had similar issues, seems to shudder under light loads 35-40mph, 60-65 mph. If you do a hard accelerate it doesn't happen. Only under conditions where tranny seems between to gears, almost like driving stick shift when RPMs are on border between two gears. Tried everything, mechanic couldn't believe it was plugs since no codes were registered by computer, no warning light, etc.
dmm5157
In my case, I did the dreaded spark plugs and coils replacement ( and lucky for me it turned out the change was easy) but it didn't fix the shudder. Wasn't until that point that I went to tyranny fluid swap. I didn't think a $5 bottle of Friction additive could get rid of that awful and embarrassing shudder, but it did.
Still glad I changed the plugs, as I'd read it does cause shudder for some, but that wasn't the issue with my truck.
PaulT
new york
Well, unfortunately I had to replace my tranny - got stuck in ice/snow 2 yrs ago and did the stupid thing we all did with tanny's of years ago - quick shift rev/fwd while rocking back/fwd -bad idea for the newer tranny's! So I was pretty sure it wasn't torque converter, did try the friction additive - no help there.
Jeremy W
Dupont, WA
I feel like I got lucky on this issue... I replaced all of the coil packs, had the cash and didn't want to troubleshoot at the time, and the shudder was gone.
drokmofo
southern az
I have replaced all plugs, trans fluid and filter change, all cop's, radiator, and oil filter adapter. I know not all pertains to the shudder. Still stuttering and not accelerating or shifting correctly. Went to exhaust shop yesterday to have backpressure tested. Drivers side cat converter plugged, passenger side close to being plugged. Hopefully after cat replacement it will be good to go
sarv1976
florida
2015 Expedition.Noticed shudder around 125,000 miles. Fluid and filter changed got rid of it. Never changed fluid before since Ford doesn’t recommend untill 150k.
