New to the EcoBoost, sound right?
catmandu
Sierra Nevada
My one week new to me 2017 makes this idle sound (check mute button bottom right corner of image if no sound):
Imgur Video
That's with the climate control off, so not the a/c, although maybe a clutch?
I've got 4k miles of powertrain warranty left, time for a trip to the dealer?
Sounds engine related, take it in before warranty is up. Almost sounds like timing chain is rattling around on my phone. I guess it’s possible the A/C clutch is going south, but mine locked right up when it went, others will chime in. Either way I’d take it in.
Black
Kentucky
Dealer for certain.
Nothing right about that.
“Good” info there, bad news. In fact I recall a recent similar cylinder head “tick” thread on F-150 forum regarding a 2016 Expedition. Same TSB was listed there regarding the piston skirts. The dealer diagnosed his as a cracked piston skirt per the tsb but he’s out of warranty. I’ll see if I can find it.
Not something that gets better with miles.
bobmbx
Dealer for certain.
Yep. Get that warranty claim lodged right now.
Its almost too loud for the valve train, sounds more like something hitting the fan.
catmandu
catmandu
Sierra Nevada
Dealer says everything's good. Service advisor initially said "that's just the injectors" but I showed him the SSM. Neither he nor the technician had heard about that. He was actually hoping that was the problem so they could get a nice warranty claim in for the engine work, but no joy. He even brought over a second tech to get another opinion. Everyone agrees, injectors and HP fuel pump noise. So it is what it is. At least I have it all documented if there are issues down the road.
Gave the rest of the vehicle a good scan as a courtesy since I am coming up on end of warranty, which was nice (Nothing found).
Keep this documented that you brought it in for this concern. I could be incorrect but I don’t believe the sound in the video to be ‘normal’. That clanking is not injector related. Can’t comment on fuel pump.
Fuel injectors make a rapid fine clicking noise.
coolzzy
Idaho
My 17 sounds very similiar, I'm at 42k miles. Dealer says normal as well, but I've got a chunk of powertrain warranty left, and cpo warranty till 100k. I get the oil changed at the Ford dealer and will drive it till it breaks I guess. If I had to guess though, I think it's csm phasers since there is no rattle on cold start (on mine anyways). I've stood next to others that were dead silent at idle and others that sound like mine, and yours with waay more miles so who knows. You should be able to extend your power train only warranty for 800 or so through Ford online. Powertrain will cover water pump phasers, timing chain, water pump, etc. Just do it before you are outside the mileage window or the price goes up.
gtncpa
NJ
I have a similar sound on my 2014 Fusion 2.0 EcoBoost. It is quieter than that and for some reason I only hear it in the cabin. (Mostly at stoplights) I have 75K on it but the sound became pronounced at 50K. 3 Ford dealers and nothing found. Maybe time chain guides?
MidwestBoater
St Louis
My '16 Expedition sounds the same and has since I bought it. These things sound a bit like a diesel at idle due to the injectors firing. I've heard a couple other Ecoboost 3.5s and they all sound like that.
mquick5
Buckeye Country
Well for now I'm glad mine sounds nothing like the one in the video.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Skip to 0:30, This is what injectors sound like....It’s a rapid ticking sound. The OPs video doesn’t sound like injectors.
mquick5
Buckeye Country
I agree OP'S sounds like rocker noise to me. But really hard to tell from videos.
gtncpa
NJ
I have gotten no response posting this on the Fusion Forum. There are very few 2.0 Ecoboost vehicles.
My 2017 Ecoboost Expi is running quiet. Here is a video of my Fusion.
Dealers claim it is normal. What do you guys think? You need to turn up the volume. Once the car goes above 1K RMP it gets quiet.
MidwestBoater
St Louis
Not a good comparison. Multi port injectors are quite different than direct injection injectors.. 35-50psi versus 200-2000psi.. DI injectors are quite a bit louder, and the high pressure fuel pump makes some noise too.
You are likely correct with the camphasers, not foreign issue to Fords. Here are a few threads on similar concerns on both gen 1 & 2 engines.
https://www.f150forum.com/f118/2017-3-5-eb-knocking-what-you-guys-think-406438/index9/
https://www.f150forum.com/f38/2013-ecoboost-return-rattle-432041/
