These fords are just different front vs back as most cars are.
The fronts have 2 13 or 14 mm bolts that hold them on. That's all.
The bolts screw into the sliding pin with the rubber boot on it.
When the caliper is "off" still hooked to hose and sitting on control arm as most people do it. you want to make sure those pins slide freely. They often do not.
You can pull them all the way out and clean and regrease or stick the Lucas Chain Lube (I'm in love with the stuff) inside the boot and spray it good then twist and work the pin around and in and out. I probably shouldn't talk like than after saying I'm in love with a can of spray lube...
Always make sure when you put the caliper back on that the long end of the pin is truned to it fits properly in the groove at the bolt hole. I really like there calipers . But no perfect design.
I like not having to have the big clips to hold pads into piston and outer on caliper, but I have had some issues with the little clips that sit on the caliper bracket that the pads sit on.
Someone asked above about grease. Most people put some grease on these and pad tip were it will slide.
I don't prefer caliper brackets but most cars have gone to it.
I think it is almost a design requirement if you have unitized wheel bearing hubs but maybe not.
No it can't be because the midsize GM FWD for years had hubs and no removable bracket. One you popped the caliper off the rotor fell right off in your hand..The way I like it.
They made the caliper "bracket" into the steering knuckle I guess.
You can rarely buy just the caliper in stock anymore. At least for older ones. They know how bad the pins stick so they only stock it with bracket for like 12-14 more so not too bad.
But I can clean and lube them for free or get new rubber boots for 3-4 IF they would stock them or new pins for 6-8 again if they carry them.
I have had to on rear of old Taurus have to drill out a broken pin in a rear caliper bracket.
That sucked. One on a Saturn once too.
I would pay the 15.00 any day instead of doing that, but on those days it was junkyard for caliper bracket or dealer at over 80 bucks.
Those ford calipers are easy to rebuild if they have kits. I ordered the last ones I did from O'Reilly for 5.85 each side. What a deal. These were on BIG box truck dually ones that were at least 60-80 each for reman ones.
Takes longer to get the thing jacked up and wheels off than to rebuilt the caliper.
Those big and old fords don't have screws or bolts!! You just drive a flat about 1/4" bar like pin in the top and bottom.
Works great though. Rear disks on E350 or E Super duty was this way and my old 79 F-350 I think too.
BTW.
While I'm on that. I had the show truck that was on the front cover or Peterson's Off Road magazine in sept of 1990 I think was the date.
A guy up in northern OH built it. He built some bigger better stuff too from what I heard later.
I bought it in Dayton, OH from a kid in 1992. Sold it in Indy Aug 23, 1995.
Was at a car show in Kettering ( old Hail and Hearty- real old Parkmor Chicken) and a guy came up and said "I know the guy who built your truck"
Kinda cool!
Will try a pic.
Anyone ever seen this beast? I have never seen it surface or a pic of it after I sold it.
79 F350 351M/400, 5 speed, dana 60 rear, 44 ground hawgs
