Aside from its nostalgic value, V-8s have no use anymore. Twin-turbo V-6 gives you much more torque, horsepower, and less fuel consumption.
You won't make many friends in the US truck world like that.
The statement is not accurate either.
Too many variables. A twin turbo...AND WHILE WE ARE AT IT!!!! Let's get ONE THING straight. Turbos: twin means nothing!! There are a lot of people that think ooooh twin turbos...TWO...that thing must be super fast or super powerful.
I want to make sure everyone knows for speed, or hp or torque....1 , 2, 3, it doesn't matter.
It is a turbocharged engine..THAT'S all that matters for these comparisons.
NOW, that I've calmed down and gotten that out....
Too many variables to say a turbo V6 gives more torque, hp and more mpg than a V8.
It's simply not true in many all cases.
It's like saying a V6 or V10 is inherently not balanced compared to a V8 or V12 so it shouldn't be made. I HAVE SAID this more than once. But the fact is that's an opinion.
There are V6 and V10s that are just as smooth as some V8s so it is relative.
I love turbo power....and I LOVE at lest one type of V6 turbo...BUT I would not want it in a truck or SUV.
In a full size truck of SUV I want 300 cubic inches minimum. I was never a fan of the 4.6 and its 281 cu in as far as displacement or power goes. The 302s were already faster in the mustangs and as soon as the 4.6 came out they had to scramble to make performance parts to get them back as fast as the engines they just replaced.
Luckily, now, the factory like to give us power- again-.
The 4.6 is a much better engine though as far as smoothness and longevity and handling abuse.
I want at lest 300 cubes and a V8.
We have only just touched on what would be the future of engines IF NOT for the electric cars which will probably take over and stop any real progress like I will mention here.
You can get more torque and hp (or at least as much) but smoother and longer lasting and no turbo(s) to replace (which you will) from a V8 and you can get mpg with cylinder deactivation (don't love it but it works) and the FUTURE.....????? valvetrain!!!
We got the V-tech that had two profiles. To basically you had a towing/low end cam at take off and midrange , then it kicked the foot out and you had a high rpm high end cam.
Then we got VVT or VCT..
These work more like degreeing in a a cam.
I did skip over simply in increasing base timing like turning a distributor that like every obdII car can do I think. Playing around with that timing gives more hp and low end but then you have a limit before pre-ignition.
But then with VVT and VCT we basically turn the cam like moving the cam srpocket one or two teeth. Like the timing sets with + an - marks.
I hope someone her is getting this and all are not just yuppies or whatevers that go pay 60k+ for a vehicle and only know specs and numbers they read and believe everything that the latest car and driver or motortrend says----They do that online now don't they? People don't buy magazines or stand there and read them all anymore. RIGHT?
SO VALVEtrain!
They have already invented and done this but it si not mainstream.
Infinitely variable self contained valvetrain...or valves or solenoids. WHatever they call them.
No camshaft needed. - good- No two camshafts needed. -even better- And Jesee Pete..NO 4 cams needed (as I sit here with a 32 valve Navi in the driveway--so overkill)-best.
Valve in the heads that independently open and close when told to by the ecm.
Sure...there will be all kinds of failures and bugs, and bent banged valves becaus eth dummies will make them interference engines.
That probably helps for mpg and stuff but can't they put them in different location ....Hemi style and compensate for whatever losses form making it IMPOSSIBLE for a valve to hit a piston...the way it should be.
But I know there are limits to what we can squeeze out of designs.
So the the valve give 2 benefits.
1: totally adjustable valve timing--DUDE- (hope you said that in surfer voice) a low power cam, a mid range, a high rpm... all in seconds.
2:Variable lift heights. This comes in later design as its more complicated but it working with the timing lets you squeeze more power and mpg out of engines.
For the astute reader who hasn't died or past out from my acute longwindedness....thise should probably be flipped as I think the towing/rv cam I referred to earlier is more about lift than timing up or down or duration of opening .
But lobe profile, ramp speed....etc etc etc....CAN ALL be done with each individual valve.
This is the evolution future of cutting edge gasoline engines but I fear it will be hampered (or should that be hindered) by the appearance or electric cars.
We'll see.
VROOOOOOM, VROOOOOOOOM!!!
